![]() Join Date: Apr 2016
Hard top removal - permanent hardware in fiberglass
My guess is this has been discussed before but I'm unable to find the thread. Has anyone drilled holes in their double wall top and used eye bolts to remove it like in the pic below? This is a late 70s/80s k5 with a half cab - think this could work for a first gen?
Here's more info on the set up: http://ck5.com/forums/threads/a-bett...ardtop.240634/ |
2WD Jimmy
![]() Join Date: Mar 2005
Re: Hard top removal - permanent hardware in fiberglass
Not a fan? It doesn't always have the eye bolts sticking out. On a 4x4 I don't think you would ever see this hardware. My main concern is will 4 anchor points be enough to lift a double wall top without ripping through the fiberglass - Kinda guessing this will be the case. Here's the hardware:
Just throw a few 2x4s under it and hoist it up. Not worth modifying the top in my opinion.
![]() Join Date: Jan 2001
Here's my rig, works fine.
#9 | |
http://public.fotki.com/blazbk/blaze...oof/page2.html |
#10 | |
I used (4) separate straps so they don't even touch the top.
Delete
#14 | |
Dbl 2x4s on top straddling trusses. Single 4x4s on bottom. ONE strap on each corner. I added a steel tether in case of strap failure. |
#15 |
![]() Join Date: Apr 2006
I think cracking the top would be a possibility with those eye bolts attached directly to the top. I can see the reasoning but the top is pretty heavy. I went with the 2x4s like others and lifting up each corner to put the chain on the bolt took a bit of strength. I would say if you did go that route there would need to be some large bracing on the underside. You may get bowing as well since there isn't support for the sides.
Kirk 72 Blazer CST 4wd highlander |
#16 | |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
That was the 1st version. Here is the 2nd version. Link to the build. http://public.fotki.com/blazbk/blaze...g-the-roof-to/ ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#17 |
