Old 10-25-2016, 09:34 AM   #1
matthamby
70 C-10 U-joints
Hello to all!
Hey guys, I'm having a small problem. I replaced the rear u-joint a few months ago, while doing so we noticed that the front and intermediate need to be replaced soon. I went to O'Reilly's Auto Parts, they don't have a stock part for those 2 parts. For some reason I was under the impression that all three were the same part. Would someone confirm that, or tell me what part number and where I can get those?
Thanks,
Matt
matthamby is offline   Reply With Quote
Old 10-25-2016, 09:50 AM   #2
B. W.
B. W.'s Avatar
Re: 70 C-10 U-joints
If I'm correct, they are all the same. The Spicer # should be 5-153X.
Bobby
B. W. is offline   Reply With Quote
Old 10-25-2016, 11:19 AM   #3
matthamby
Thanks,
I will advise once I have them!
Old 10-25-2016, 11:33 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Spicer 5-1310x if you want the good ones.
Why not take it to a drive shaft shop since it needs to be rebalanced anyways (especially if its the ld carrier bearing)? They might notice something you wouldn't.
brad_man_72 is offline   Reply With Quote
Old 10-25-2016, 12:26 PM   #5
LongBox
Plus one on driveshaft straightening/balancing. Made a huge difference on another vehicle I had. And, I'm not sure if it's a do-able, but the 88-98 pickups have a large diameter aluminum driveshaft and no center steady bearing. Not sure if you could do that to your truck, but someone else may chime in.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-25-2016, 01:18 PM   #6
matthamby
if you mark it correctly, it shouldn't need to be re-balanced, plus it takes more $$$ that I don't have at the moment to take it to a shop. I'll replace them, then if I need them balanced, I'll take it to the shop. right now everything feels good and no noticeable noise, etc...
I'm trying to get it to be dependable while I am working on getting other items replaced - like a new rear axle and tranny, which may require the drive shaft to be replaced. At that point I'll probably need a shop to build me a new drive shaft. I do appreciate the help!
Old 10-25-2016, 02:17 PM   #7
B. W.
B. W.'s Avatar
X2
Sorry, should have listed those, they are "Lube for Life". My favorites!
Old 10-25-2016, 02:34 PM   #8
matthamby
Thanks guys!
I'll use the 153x ones, I have to lube everything once a year anyway. plus as stated hopefully in the next 2 to 3 years I'm going to have to have a driveshaft made for it. Right now I've got a low HP 305, i'm driving it about 40 miles a week on average (haul trash and the occasional trip to Lowe's), so it's not critical that I get the really nice ones.
Old 10-25-2016, 08:12 PM   #9
brad_man_72
the boat guy
Definetly mark everything. But the balance will change when you start changing parts like ujoints or carrier bearings. I know because I've had shafts in a balancer, taken them out, changed a joint or bearing and put the shaft back in the balancer, every time the balance will change. This isn't a big problem with a one piece shaft or even a 2 piece shaft with a standard horseshoe style carrier bearing, the light duty cb that gm used in the 60s will not last with an out of balance condition. You won't feel it in the butt dyno because the cb rubber is the softest cb rubber mount that I've seen out of thousands of drive shafts.
You can go to a one piece shaft but it has to be made from 3.5" diameter tubing. A large aluminum shaft won't fit through the trailing arm crossmember. Many shops won't build a one piece 3.5" shaft for a lwb 67-72 because the length exceeds the tubings limits under some circumstances. I've built a dozen or so with no issues.
Old 10-25-2016, 08:27 PM   #10
wbc409
You will need to measure the length carefully. The local drive shaft shop told me they wouldn't build a shaft over 70 inches.
wbc409 is offline   Reply With Quote
