Old 10-25-2016, 06:50 PM   #1
solidaxel
solidaxel's Avatar
4l60E Range Connector
I have a 2003 4L60E and the harness I received has this connector.
Is there a different switch I can place on my transmission 0r do I need a different harness connector?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-25-2016, 06:55 PM   #2
michael bustamante
michael bustamante's Avatar
Re: 4l60E Range Connector
the gray one? my 03 harness doesnt have that one either
5.3 4l60 2wd. (mine)
wonder if its for 4wd
1967custom
michael bustamante is offline   Reply With Quote
Old 10-25-2016, 08:38 PM   #3
clinebarger
Your harness is set-up for a 2004 & newer Range Switch, It will bolt right up to your 2003 4L60E.
clinebarger is offline   Reply With Quote
Old 10-26-2016, 09:56 AM   #4
solidaxel
solidaxel's Avatar
Thanks again Cline, I knew you would have a solution !
Is there any other changes in a 03 wiring harness for the transmission or is a 04 the same?
The other harness I have do not even have a connection,connector, for the transmission at that location
LS 3 4L70E
Old 10-26-2016, 11:24 AM   #5
Hart_Rod
Hart_Rod's Avatar
My aftermarket harness didn't even come with a range connecter, not sure it is even required.
Hart_Rod is offline   Reply With Quote
Old 10-28-2016, 11:35 PM   #6
solidaxel
solidaxel's Avatar
I found this one, will it work?
ACDELCO D2257C {#24221125} GM
LS 3 4L70E
Old 10-29-2016, 01:03 PM   #7
ls1nova71
ls1nova71's Avatar
Yes, that's the one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-29-2016, 03:13 PM   #8
solidaxel
solidaxel's Avatar
Thanks Folks !!
LS 3 4L70E
