Wide n'Low
![]() Join Date: Jan 2007
LM4 mod suggestio for project Goldmember
So this weekend my son brought home an all aluminum 5.3 (LM4) for my project Goldmember Suburban.
Curious to see what you all think I should add/ modify. I'm not looking for anything overly aggressive on this, just not stock. I'll most likely run a 4l60 and keep the 3.73 gears Just thought I'd ask here too as I begin my research Thought?
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Re: LM4 mod suggestio for project Goldmember
With a good tune the LM4 runs pretty good for a driver/cruiser. They have good heads on them, a pretty good cam, and intake too.
meowMEOWmeowMEOW
Cam kit (springs/pr's/guides) and a tune with a good set of manifolds or headers is really all you need to get cruising with a lil more power.
If you need more than that, you can consider a small shot of n20 without changing much at all. Or you can consider running a slightly more aggressive N/A setup, and using methanol to keep it fun on pump gas.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | ||
Wide n'Low
Thanks, that is pretty much what I have found most everyone suggests as well. Looking forward to getting after this..
