Old 10-10-2003, 07:31 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Too much timing
I was out cruising around in my truck today, and i noiticed a little spark knock while pulling a hill. So, i stopped and backed off the vaccum advance timing (Crane adj. vaccum advance) about 3 degrees.
And wow!! The truck runs alot better with less timing! Throttle response, midrange power, and idle quality all impoved. It even seems that the full throttle power increased too, but i hadn't gotten into the 4bbl in awhile so it's hard to say.
I was kinda under the impression that an engine usually runs best with the timing advanced as much as it saftely can be w/o pinging. It usually dosen't ping, i just had filled up with a tank of cheap 91 octane fuel (proably the problem).
I am running 11 degrees of base timing on a stock HEI, the Crane blue and silver mech. advance springs, .045" gapped plugs, and 9.7:1 compression with a 204/214 cam.
Is there an easier way to figure out the ideal timing for my engine than the "seat of the pants" method?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
