Old 12-03-2016, 01:13 AM   #1
Kinger615
Gas tank..... cradle????
Any suggestions on how to remove the gas tank cradle that sits behind the seat? I see numerous spot welds just wondering if there is a easy way to remove. Thanks
Kinger615 is offline   Reply With Quote
Old 12-03-2016, 02:04 AM   #2
'63GENIII
'63GENIII's Avatar
Re: Gas tank..... cradle????
I think there are two 1/2" bolts and two 5/16 bolts for each cradle. IIRC, one of the 1/2" bolts goes through the cab bushings as well. I don't remember seeing spot welds on mine.
I almost pulled mine out a few weeks ago but decided to used them to hold my speaker and behind the seat storage unit that I'm going to install.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-03-2016, 08:54 AM   #3
Vinceg
Vinceg's Avatar
Kinger615 there isn't really an easy way to remove the spot welds short of using a spot weld remover bit for a drill. I found the spot weld remover bit I had bought went dull before I ever got to the gas tank mounts. I was using a regular drill bit so I ended up with dimples that I had to fill weld and grind back down. The spot weld remover bit leaves a bit of the spot weld behind that can be ground off after. At least the one I had did. It worked well till it got dull.
Vince
Vinceg is offline   Reply With Quote
Old 12-03-2016, 09:09 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
I used a Makita and a cutting disc. You have to be careful though and use max control or you will cut through the trucks sheet metal. On the backside of the cab I used a piece of steel to slide down into the bracket to assist in not cutting the trucks sheet metal. Grinding to suit.
Once you start you'll get it, just don't try and go too fast.
Old 12-03-2016, 01:59 PM   #5
KenAdams
KenAdams's Avatar
+1 for a cheep spot weld cutter from Harbor Freight and patience. Think it probably only took and hour to get both of mine out. I started at one and gradually used a putty knife between the two to exagerate the difference. Then when I was finished just cleaned everything up with a flap wheel.
KenAdams is offline   Reply With Quote
Old 12-03-2016, 02:23 PM   #6
Blue666(2)
+2 The cradle is a bit thicker than the floor or back wall so it's easy to push a drill bit right through (insert voice of experience here). The spot weld cutters work a bit better. You can also work the blade of a screw driver between the two pieces and this helps it pop apart.
Blue666(2) is offline   Reply With Quote
Old 12-04-2016, 01:44 PM   #7
Kinger615
Thanks for the advice everyone.
Old 12-05-2016, 10:15 PM   #8
racecougar
racecougar's Avatar
I took a slightly different path, leaving behind the back portion of the mount. I cut off the front, pie cut the sides, laid the material down, welded it, then smoothed the welds out.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-06-2016, 02:57 AM   #9
Kenfuzed
Kenfuzed's Avatar
Nice job, just wish the pictures weren't on photobucket with all the annoying pop up ads.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 12-06-2016, 09:34 AM   #10
The Rocknrod
Moderator
I know, I have to find a new place also.
Old 12-06-2016, 02:31 PM   #11
racecougar
racecougar's Avatar
Ditto. The problem is, when I transfer all of my photos over to another hosting site, I won't be able to edit the links in my posts here. I don't understand why we can't go back and edit our posts here.
Old 12-07-2016, 03:55 AM   #12
Kenfuzed
Kenfuzed's Avatar
Hi Rod, there should be an Edit button at the bottom of each of your posts. At least I see one below mine. Yeah I know it's a hassle to edit every single one and it's not your fault or anyone who has used them. I blame Photobucket for being so intrusive and pimping their ads on every user's page. I get that they have to make money, but the popups that take over the page turn more people away. Then again, this forum could set up a gallery to host pics... but I digress JMHO
Enjoying the ride!
Old 12-07-2016, 11:17 PM   #13
racecougar
racecougar's Avatar
Ken, the edit button disappears after a very brief period of time (maybe an hour). For instance, I can't edit the post I made above yesterday. I'll be able to edit this post for a short period of time, then it too will be locked henceforth. No other forum I've been a part of has had this practice of locking in posts for eternity.
