Old 12-13-2016, 12:51 PM   #1
Tom
driving is in my blood
Tom's Avatar
Alignment vs tire wear?
My 1998 is lowered with 2" spindles and 3" springs up front. I've always run factory alignment specs, and the tires aired up to the max on the sidewall [usually in the 50psi range when truck called for 35 on sticker] and yet I still wear the edges out with the centers like new. Wears evenly on both sides like this. Any alignment tricks I can do to help with the wear?
Old 12-13-2016, 08:40 PM   #2
racecougar
racecougar's Avatar
Re: Alignment vs tire wear?
You're wearing out both the inner and outer edges before the center, or just the inner OR outer edges before the center? Can you post your current alignment printout?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-13-2016, 09:36 PM   #3
SCOTI
SCOTI's Avatar
I target the opposite of camber specs set by GM (if they say the camber range is .5 POS; I do .5 NEG). Tire wear is still within range & NEG camber helps keep the tires planted.
Adjust for the most Caster possible w/the NEG camber.
Wearing inside & outside edges sounds like Toe is not set right.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-14-2016, 12:41 AM   #4
ol'blazer
ol'blazer's Avatar
if its on both edges of the tire I'd say its more of a toe issue. if you run a little more positive on your toe it might help take up slight play in the linkage as you're driving. if i remember right spec is -5 to +15 on those trucks, so id probably set it to +7ish
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 12-14-2016, 11:01 AM   #5
cg285
caster causes no tire wear, camber would have to be extreme to show wear. most all wear, from misalignment, is toe. but toe will not wear both edges and leave the center alone.
rub your hand across the tire and see if you can feel a directional wear.
if there is a wear edge toward the outside it is toed too much out (you would feel that running your hand from the outside to the inside), if to the inside too much toe in
if you feel no wear edge then your issue is either driving habits or some tires just wear oddly. many times i have seen one or two treads wear badly while the others were fine - and it was never an alignment issue.
cg285 is offline   Reply With Quote
Old 12-15-2016, 01:56 PM   #6
Tom
Tom's Avatar
Both inner and outer. I don't keep the spec printouts usually just the receipt.
Truck has been this way for 100,000 miles now. Its had BFG's, Nitto's, Michelin's, and kumho's all do the same thing, and it's been aligned by at least 3 different shops. Front end has had basically everything replaced over that time and is in excellent condition. It drives great, just wears out my tires quickly. I have some ideas to try now, thanks guys!
