Old 02-01-2016, 10:28 AM   #1
Hart_Rod
Hart_Rod's Avatar
GM Pulse Generator for electric speedo
This a new part. They list for $129 from DD, I will take $80 shipped..
The missing piece of the increasingly popular early-GM transmission swap!
With late-model GM transmissions containing an internal speed sensor outputting 128,000 Pulses Per Mile, the stock 40-tooth (40 pulse per revolution) reluctor ring provided the factory ECM with a high frequency input. The SEN-01-128 can now recreate this missing high frequency rate when converting to an older style transmission with a mechanical speedometer output.
With a standard female 7/8” thread-on fitting, the SEN-01-128 fits all GM transmissions with a mechanical speedometer cable outlet. Removable weather-tight 10’ cable provides for simple installation and cable routing. 128,000 Pulse Per Mile Sine Wave signal output is direct replacement for the stock GM internal speed sensor, allowing the ECM receive the signals it needs for proper operation.
Fits GM transmission models with 7/8” Male Threading, ie: TH350, TH400, 700r4, 2004r, etc.
http://www.dakotadigital.com/index.c...rod/prd916.htm
Hart_Rod is offline   Reply With Quote
Old 02-01-2016, 11:26 AM   #2
michael bustamante
michael bustamante's Avatar
Re: GM Pulse Generator for electric speedo
so this is not for the 4l60 then?
1967custom
michael bustamante is offline   Reply With Quote
Old 02-01-2016, 11:34 AM   #3
Hart_Rod
Hart_Rod's Avatar
Michael - 4L60e's have a built in signal generator.
Old 02-05-2016, 12:33 PM   #4
Hart_Rod
Hart_Rod's Avatar
bump
Old 02-05-2016, 12:52 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
So this is for the LS crowd that wants to run an older model trans?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-05-2016, 12:59 PM   #6
72MARIO
72MARIO's Avatar
Do you know of there is a way to T the speedo cable and still be able to retain the mechanical speedo ? I dont want to switch to a electric speedometer. I would like a vss signal for my ls swap but plan to keep my 400 and gv od setup. If there is a option to t the cable i will take it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-05-2016, 03:20 PM   #7
Hart_Rod
Hart_Rod's Avatar
Yes or you can run an electric speedo with the older transmission.
When you swap to an LS you will need the signal from this to go to the computer.
Old 02-05-2016, 03:47 PM   #8
72MARIO
72MARIO's Avatar
Do you know if there is any way to split the cable and run this as well as the factory speedometer cable ?
2005 TAHOE DD
Old 02-05-2016, 04:08 PM   #9
Hart_Rod
Hart_Rod's Avatar
This "might" work, but I would call and explain what I'm doing before purchasing.
http://www.dakotadigital.com/index.c...rod/prd109.htm
R
Old 02-11-2016, 06:15 PM   #10
Hart_Rod
Hart_Rod's Avatar
Bttt
Old 02-13-2016, 12:04 AM   #11
68gmcdually
68gmcdually's Avatar
Hey 72MARIO, I could've saved you the shipping costs, and picked it up.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 02-19-2016, 09:26 AM   #12
Hart_Rod
Hart_Rod's Avatar
bump
Old 02-29-2016, 09:03 AM   #13
Hart_Rod
Hart_Rod's Avatar
bump
Old 03-28-2016, 10:25 PM   #14
Hart_Rod
Hart_Rod's Avatar
bttt!
Old 03-30-2016, 11:36 PM   #15
lutronjim
Don't know if they are still around, but taxi cabs had a splitter to run their meter.
lutronjim is offline   Reply With Quote
Old 04-02-2016, 02:49 PM   #16
Hart_Rod
Hart_Rod's Avatar
bump
Old 04-13-2016, 12:12 PM   #17
Hart_Rod
Hart_Rod's Avatar
ttt
Old 04-28-2016, 09:12 AM   #18
Hart_Rod
Hart_Rod's Avatar
bttt
Old 10-19-2016, 01:33 PM   #19
Hart_Rod
Hart_Rod's Avatar
bump!
Old 01-20-2017, 02:02 PM   #20
LowLifeS10
LowLifeS10's Avatar
Still available?
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 01-20-2017, 02:29 PM   #21
Hart_Rod
Hart_Rod's Avatar
Originally Posted by LowLifeS10 View Post
Still available?
yes it is!
Old 01-20-2017, 03:38 PM   #22
LowLifeS10
LowLifeS10's Avatar
Originally Posted by Hart_Rod View Post
yes it is!
Ok, I just need to do some research about this thing, I'll get back to you!
Old 01-23-2017, 09:22 AM   #23
Hart_Rod
Hart_Rod's Avatar
What did you figure out?
