Old 12-19-2016, 12:44 AM   #1
ClemSmith
1964 C10 V8 battery cable routing
What is stock 12V battery cable routing from battery + to starter and battery - to ground for 1964 C10 with V8 motor?
What are correct lengths?
Where does negative/ground cable attach to ground point on motor or frame?
Does positive cable clamp to frame or inner fender skirt along path to starter?
There are 3 unused 1/4" holes in inner fender 1" above frame.
Were both cables black originally?
Looks like there was also a short 10-12 ga ground wire attached to radiator support frame sheet metal near battery and a long 10 ga wire from battery positive post cable terminal, through grommets & inside radiator support to voltage regulator.
Thanks, Clem
ClemSmith is offline   Reply With Quote
