Cam shaft help!!!!
Dear friends and fellow truck nuts. I am in need of some help. I built a motor for my 1969 C10 that was going to be a pro street build. About half way through the build someone made me a offer to buy the truck that I could not refuse. I ended up buying a beautiful 1980 square body and I would like to put the motor I originally built for the pro street truck in the new 1980 but I need to tone down the cam.
The cam that is currently in the motor is a comp cams XE294H. It needs a 3300+ stall converter and in my opinion is to much for a truck that I would like to drive on a regular basis. The 1980 has a Turbo 350C (electric lock up) in it and I bought a 2500 stall hughes converter. I will list out all my motor info and if you guys could help point me in the right direction I would greatly appreciate it. I would like the truck to have the most power possible but still be streetable. This is a toy so I do not really care about fuel mileage. I would like a decent amount of lope if possible. Thanks guys and MERRY CHRISTMAS! VEHICLE: 1980 SINGLE CAB SHORT BED TRANS: TH350C WITH A 2500 STALL CONVERTER GEARS: 3.73 MOTOR: 383CI, 10.3:1 COMP RATIO HEADS: 190 RUNNERS 72CC CHAMBERS INTAKE: RPM AIRGAP CARB: 750 HOLLEY DOUBLE PUMPER
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES) |
60-66 Nut
Re: Cam shaft help!!!!
With that high of a static compression, you will want to be careful going with a smaller cam that may create too high of cylinder pressure for pump gas. I don't think I would go any smaller than the XE268H, and that may be too small. Maybe the XE274 or XE284.
Would a narrower LSA help with keeping the dynamic compression in check? Not saying that I know anything about cams, just curious and trying to learn.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#4 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
A little info to feed the fire.
http://www.crankshaftcoalition.com/w..._compatibility |
Thanks Geezer. Good read there.
I think im going to go with the 284. The 2500 stall will match that a lot better and the power will come on closer to the right spot than the 294.
1980 TURBO C10
Before you go swapping cams, what's your timing set up like?
What's initial? How much in the mechanical? |
#10 | |
1980 TURBO C10
The motor only has a few hours on it from letting it idle and breaking it in. Im ready to get this thing under the hood. Im just so on the fence about the cam. Id love to keep it cause the idle sounds pretty mean.
If I do keep the cam I will deff need help tuning the carb. Ive got a AFR gauge to put in the truck once I get it installed. I figured that would help with the jets and setting the idle mixture.
1980 TURBO C10
Looks like you're over-thinking it!
Put it in and then fine tune it and if you got a problem then it's not hard to swap out a cam. |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'm interested in that AFR gauge, how does it get it reading? O2 sensor? I'm assuming it's a digital gauge?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
It runs off a 02 sensor in the header and lets you know if your running rich or lean
1980 TURBO C10
#15 |
[QUOTE=SLDPULR;7805890]The motor only has a few hours on it from letting it idle and breaking it in. Im ready to get this thing under the hood. Im just so on the fence about the cam. Id love to keep it cause the idle sounds pretty mean.
If I do keep the cam I will deff need help tuning the carb. Ive got a AFR gauge to put in the truck once I get it installed. I figured that would help with the jets and setting the idle mixture.[/QUOTE Tuning the carb likely will only be a power valve change. Best tuning is done with the timing. Then 99% of the time the carb is almost spot on. |
