Old 12-21-2016, 06:57 PM   #1
C10agent
C10agent's Avatar
Lubricate? Grease? Anit Seize? Question
So I am a Noob and happy to admit. I have effectively torn my truck in half, now I am rebuilding and wanted to make sure I am doing everything correct. I am simply looking for advice of when to use what to make sure that bolts don't get seized and my truck doesn't decided to break in half when I put some miles on it. Just some rules of thumbs if you guys have it. Thanks for the advice, you guys are a wealth of knowledge!
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 12-21-2016, 07:20 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Lubricate? Grease? Anit Seize? Question
Here's my two cents worth. I use anti seize on any aluminum, stainless and most steel bolts that go into a blind hole. The exception being a bolt that requires loctite on the threads.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 12-21-2016, 08:56 PM   #3
LongBox
Not sure whether you are going into the engine, but any bolts or studs that go into the water jacket should have sealer on them to stop the coolant from coming up the threads.
Also, be careful with bolts or nuts that you are torquing, as the torque specs might be for clean dry threads, not lubed threads.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 12-21-2016, 09:19 PM   #4
C10agent
C10agent's Avatar
Thanks guys! Any special brands y'all use and like? Also, other than a good grease for most suspension parts, anything else y'all use?
Neil...............
TEXAS Y'ALL!!
Old 12-29-2016, 02:29 AM   #5
El Dorado Jim
I just use clear silicone, non hardening type comes in a tube, I think home depot has it, it is used for o rings and faucets....it is a great anti-sieze and i use it on all nuts and bolts....except I use a silicone sealant for water jacket holes...
El Dorado Jim is offline   Reply With Quote
Old 12-29-2016, 08:41 AM   #6
67 chevelle
67 chevelle's Avatar
Antiseize is a must on anything stainless , or anything going into aluminum
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
