Old 05-15-2015, 02:52 PM   #1
Robznob11
Robznob11's Avatar
homemade tilt hood video
Subject:Watch "67-72 homemade tilt hood" on YouT, https://youtu.be/9kogRMi0ue0.
Well the shocks drastically help the ease to open and shut the hood. I need to make some brackets to hold springs and limit how far forward the hood can turn so it won't hit the grille. Thought someone may want these ideas
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-15-2015, 07:09 PM   #2
jessemthompson
Re: homemade tilt hood video
Great job man.
jessemthompson is offline   Reply With Quote
Old 05-15-2015, 07:12 PM   #3
Custom/Ten
Custom/Ten's Avatar
Wink Re: homemade tilt hood video
Cool man, thanks for the "ideas"! Can I have the motor too!
Custom/Ten is offline   Reply With Quote
Old 05-15-2015, 07:22 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work! I bet that took some trial and error to get working that easily!
Ryan
1969 Chevy milk truck
Old 05-15-2015, 10:35 PM   #5
Robznob11
Robznob11's Avatar
Yes sir, many trials but works good now. I have less than 100$ in the setup
LED TAILS
Old 05-15-2015, 10:49 PM   #6
AirSpeed
AirSpeed's Avatar
That's very very cool! Nice and clean! Great job!
AirSpeed is offline   Reply With Quote
Old 05-16-2015, 06:34 AM   #7
spidermn
spidermn's Avatar
That is completely different from anything i've seen. great job!
Go BIG or GO home!!
1970 Custom Chevy C10 / 350 bored .30 over / 5.5/7 drop on 20" boss 338
spidermn is offline   Reply With Quote
Old 03-16-2016, 03:39 PM   #8
Custom/20
Custom/20's Avatar
Nice job man!
Custom/20 is offline   Reply With Quote
Old 03-17-2016, 10:26 AM   #9
snipescastle2
snipescastle2's Avatar
Talking Re: homemade tilt hood video
That's Sweet! Great job!
Ben
snipescastle2 is offline   Reply With Quote
Old 01-14-2017, 05:20 PM   #10
88Stanger
88Stanger's Avatar
robznob11
this is awesome!! do you have a how to build on this?
88Stanger is offline   Reply With Quote
Old 01-14-2017, 05:50 PM   #11
Rod Run
Rod Run's Avatar
Looks like it works pretty damn good
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 01-14-2017, 08:23 PM   #12
Robznob11
Robznob11's Avatar
Originally Posted by 88Stanger View Post
robznob11
Sir. I dont have a build on it but i can get some pics and some measurements in a day or two and post up. It consists of maybe 1-2 foot of 1 1/2 angle. A stick of small square tube and a little bit of plate . Oh and a couple of eye bolts i welded on the ends. They were for a fence gate from tractor supply. It was just trial and error till i got it right. I can get you in the ball park for sure. One thing to note. The aftermarket hood has two braces that runs parallel down each side of the scoop. Stock does not so it may not be as easy with a stock hood. With that said i built slider brackets for under the hood so i do have alittle adjustment if needed. Also allows the bracket to be removed pretty easy. The rear latches i cut the top section of the oe hinges. That allows me to bolt those brackets in the oe holes and stack shims to raise or lower the back as well. When the back sliders fall into the slot and the oe front latch is engaged it is positively locked down front and back. The rubber isolaters keep it located for the most part between the fenders.
LED TAILS
Old 01-15-2017, 02:23 PM   #13
88Stanger
88Stanger's Avatar
If you would not mind getting the measurements that would be awesome! I just really like how simplistic it looks and performs.
Old 01-14-2017, 07:10 PM   #14
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: homemade tilt hood video
Very nice sir! Well done.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-14-2017, 08:26 PM   #15
Robznob11
Robznob11's Avatar
Also i abandon the springs and went to a prop rod to keep it off the front end. Ill get pics of it too
LED TAILS
Old 01-14-2017, 10:56 PM   #16
Shinysideup
Shinysideup's Avatar
That is certainly trick, any wind will wreck your day though.
Shinysideup is offline   Reply With Quote
Old 01-15-2017, 12:15 AM   #17
Robznob11
Robznob11's Avatar
Um i assum you mean a windy day with it open. Cause when its closed its not going anywhere. I did this mod caus my truck will go low enoug that it would hit stock hinges. It is more sturdy than you think. You can also prop it @ 2/3 open the normal way.. if you extended the rear catch you could probably get mor than that.
LED TAILS
Old 01-15-2017, 11:12 AM   #18
Hook'em
Hook'em's Avatar
Wow.
And to think I was excited installing new bumper stops under the hood the other day.
Hook'em
Hook'em is offline   Reply With Quote
