Old 12-18-2016, 12:37 PM   #1
geasson
carb upgrade or rebuild
I have a 1966 1-ton with a V6 that has been sitting for a long time. It has a 2-bbl Stromberg on it that needs rebuilding. Should I rebuild it or upgrade to a newer 2-bbl Holley?
geasson is offline   Reply With Quote
Old 12-18-2016, 04:27 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: carb upgrade or rebuild
The 500 cfm holley 2 barrel is a common carb swap and offers much better performance of the stock 2 barrel. That and dual exhaust wakes these up nicely.
Old 12-19-2016, 09:47 AM   #3
geasson
Is that a straight bolt on swap or do you need to change manifold? Also, what about an air cleaner?
Old 12-19-2016, 11:37 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
What size v6 do you have?
Old 12-20-2016, 11:14 PM   #5
geasson
It is a 305E
Old 01-23-2017, 10:53 PM   #6
geasson
Is the Holley a bolt on upgrade for a 305 E V6? What about an air cleaner, can I use the stock one off of the Stromberg??
Old 01-23-2017, 11:16 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
You'll need this adapter:
http://www.ebay.com/itm/Mr-Gasket-19...NWuzKa&vxp=mtr
The stock one will not work. Any 4 barrel aftermarket air cleaner will do nicely.
You will also need to modify the throttle linkage and fuel supply.
Old 01-25-2017, 09:22 PM   #8
geasson
Thanks for the info
