Old 02-02-2017, 05:49 PM   #1
Daimler
1968 3/4 4x4 5 spd trans swap?
Hello, I have a 68 Chev 3/4 ton 4x4 with a 350 and the stock 4 spd trans and stock transfer case. Both were rebuilt when I installed 1985 4:11 one ton diffs front and dually rear. (the original diffs were 4:56) I was wondering if a modern 1 ton 5 speed overdrive manual transmission can be fitted. (I remember a Torque Flyt auxilary tranny that could be placed between the existing tranny and the bell housing. It was 7 1/4 inches long and was rated for about 7500 GVW. It gave about 30% overdrive. I do believe another shift stick in the cab is great but I am not sure they are available any longer. Changing the drive shaft lengths is no issue.) I suppose it may be possible to swap the tranny and transfer case together to make it all a little easier, but I want to find out if a modern heavy duty 5 speed can be fitted to the original transfer case. Maybe someone here has done this swap? Presently I get 9 to 12 miles/gallon loaded.
Daimler is offline   Reply With Quote
Old 02-02-2017, 08:01 PM   #2
franken
Re: 1968 3/4 4x4 5 spd trans swap?
An NV4500 is the usual 5-speed swap. The usual TCs to use are passenger drop NP241 and NP205. You might try NW fab, ORD and advance adaptors for an adaptor. A round pattern 32 spline 205 will bolt to a GM 4x4 NV4500, but needs a spacer or input gear change.
Old 02-02-2017, 09:27 PM   #3
Daimler
Than-you for you reply. I will check thiese out.
Old 02-02-2017, 09:40 PM   #4
bluek5
bluek5's Avatar
Here is a thread about a NV 4500 swap.
http://67-72chevytrucks.com/vboard/s...highlight=4500
bluek5 is offline   Reply With Quote
Old 02-03-2017, 01:45 PM   #5
Daimler
Thanks Blue
