Old 02-19-2017, 03:32 PM   #1
munztead
Axle Shaft Identification
I need some help, or I may be overthinking this but here goes.
I put a used rear end under my 78 C10 a few years back. Unfortunately, I can't remember what the junk yard took it off of other than a GM. I've gathered all the number I can off the housing and they are:
14055251
B276
GM34
It's a 10 bolt 8.5 differential, and what I really need to know is what year the thing was made. I believe it's a 83 or 86. I'm trying to order new axle shafts, but running into issues regarding the length. When I measure entire length, it comes out to be 31 7/16, which I can just say 31 1/2, but finding 31 1/2" axle shafts 5on5 bolt pattern isn't too easy.
Are these normally 31 3/8?
Any assistance is greatly appreciated. I've been researching for days and getting frustrated.
Thanks in advance!
munztead is offline   Reply With Quote
Old 02-19-2017, 08:01 PM   #2
b454rat
Re: Axle Shaft Identification
I wasn't aware that there was different length 10 bolts for trucks. From 78-ish to 88, after that they switched to 30 spline. But don't forget the 88 up style, they are narrower...I think....also check the ring gear, it will have a date stamp on it.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 02-19-2017, 10:05 PM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
83 or 86 would be the same axle. Randys says 31 5/16"
https://www.ringpinion.com/b2c/Produ...rd&ShowAA=true
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
