Old 03-18-2017, 08:28 PM   #1
62bagger
62bagger's Avatar
Rear trailing arm torque
I just replaced the trailing arm bushings on my 62 and I was wondering how much to apply when I put the bolts back in. any help would be appreciated.
62bagger is offline   Reply With Quote
Old 03-19-2017, 11:04 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Rear trailing arm torque
Bolt tourque chart suggest 80 ft lbs for grade 8, 1/2"
115 for 9/16"
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-19-2017, 05:23 PM   #3
62bagger
62bagger's Avatar
Thanks for the information.
Old 03-20-2017, 10:40 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
From the GM manual, those are 140 ft. lbs and you want them at ride height when you torque them, not hanging down.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-22-2017, 12:36 AM   #5
Sik5chevy
I did 140 as well
Sik5chevy is offline   Reply With Quote
