66 burb driveshaft angles
what are you guys running for driveshaft angles with your swaps? 5.3/4l60 in a 66 burb, factory 72 v8 stands, cpp crossmember is 1.5 inches lower at the trans mount than my factory 71 crossmember is. its putting the ujoint angle at the trans at 5 degrees(factory 2piece driveshaft with a cpp trailing arm drop crossmember). did cpp build their trans crossmember wrong? the trans mount is level with the bottom of the frame.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
![]() ![]() Join Date: May 2015
Re: 66 burb driveshaft angles
You could stick a spacer in under the mount to raise the back of the trans...bolt length allowing..I think 3 degrees is what most people shoot for..just make sure it matches your differential angle
I think I'm just going to make a new crossmember. this one is too far out for me.
CPP builds EVERYTHING wrong, Find a factory automatic crossmember!
![]() Join Date: Apr 2005
Try ECE.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Apr 2010
I am thinking about using this trans crossmember but I haven't seen many people use it.
https://www.ifabspeed.com/product-pa...ns-crossmember |
#7 | |
#8 | |
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
