High idle and elevated timing
Just acquired a 71 C20 and the plug wires were crumbling apart. Changed plugs and wires. PO had already added HEI.
I set the timing the old school way. Retarded the timing until when I romped on it, there was no pinging. Newbie question: It *sounds* like its idling a little high. When I put a timing gun to it, it reads 32 at idle. Now, I've read the total timing should be around 32. Those two things combined make me think its idling far too high. My idle speed screws are turned all the way out. Can anyone point me in the right direction? 71 C20 350 and quadrajet are original Last edited by 71rehab; 05-12-2017 at 10:35 AM. |
Re: High idle and elevated timing
Old school, eh!!
Nobody 'old skool' ever did that. We plugged the vac pot off, drove uphill in high gear at 30 mph and advanced until it pinged then pulled it back a hair! Plugged the pot back in, turned down the idle, adjusted the mix screws and went out to find some fords or mopars to blow off the street! old skool indeed! |
![]() Join Date: Nov 2007
Take the reading at idle with the vacuum advance plugged. Is it plugged into ported or manifold vacuum?
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
![]() Join Date: Feb 2016
Yes the timing is way to high at initial. Should be in the 8 to 12 degree range with the vacuum advance disconnected and plugged. Bringing the timing down will mean readjusting the idle speed down too. Ideally when you get the initial timing correct you will have backed the idle speed screw out closing the butterfly's enough for the idle mixture screws to work again. Find a tach and dewel meter to check your idle speed. They are easy to find cheap and used. Nobody seems to want them any more. At least around here it seems that way.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#5 | |
Is it possible that the HEI was installed incorrectly such that I can still get a reasonably well-running truck without an accurate timing reading?
#9 | |
As mentioned previously plug it and for a stock-ish cam shoot for 10-12 at idle, removing some advance should bring the idle down some too.
If you are running a Q-jet the throttle shafts get worn & cause a high idle even with the screw backed out. Check the mechanical advance in the HEI unit. They are known to get dry & freeze up.
I tried covering the carb with a rag and the truck kept running. I've read this means that I have a vaccum leak. I sprayed WD40 around the gaskets and didn't see any sign of a leak.
My should this choke valve be completely closed at idle when the engine is warm? Sorry for the beginner questions. https://drive.google.com/open?id=0B9...3pncllWVmhLQWM https://drive.google.com/open?id=0B9...TFwLVEyUWZPbEk |
Just a related question here: If you run 10 - 12 degrees initial advance (vacuum plugged, engine idling around 650), is it necessary to run premium fuel, or to limit the total centrifugal advance in the distributor?
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#13 | |
#14 | |
The Choke flapper should be completely open when up to operating temperature. The only time it should be completely closed is at cold start up after pumping the accelerator pedal prior to start up. Then it should be about 1/4 inch open. It will then slowly open fully up as the engine warms.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-12-2017 at 08:08 PM. Reason: -2 spelling |
#15 |
It is quite possible that you may need to run premium fuel. It would depend on the compression ratio of the engine. If your trying to run a high compression engine on low octane fuel you should retard or limit the available timing to prevent detonation. Timing is set in accordance to compression ratio not the other way around. Engines with low compression, a large bore, and large compression chamber will always need more timing than a high compression, small bore, small compression chambered engine. Largely due to the greater distance the flame front has to travel.
#16 |
Yep that worked. Just had to move each of the plugs over by one post to give me the clearance to retard to 12 and now its starting and running much better. Thanks!
