Old 04-05-2017, 07:16 PM   #1
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
I guess my steering box is bad
Got my front end together and took it to Les Schwab Tire Center and was told my Steering Box is too tight, needs to be replaced. I haven't even put 100 miles on it and it's herky jerky and stiff. On the freeway it feels like it starts to pull one way or the other and I have to really stay on top of driving because it doesn't seem to return, if you know what I mean. But I guess the alignment is good.
lifetime warranty so do you think I should send it back and get another? Just confirming unless someone knows something I don't. I guess they don't adjust them anymore.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 04-05-2017, 07:38 PM   #2
NoStopN
NoStopN's Avatar
Re: I guess my steering box is bad
Hilariously, when I had my ball joints put in last year, the shop told me that they tightened mine up.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 04-05-2017, 08:17 PM   #3
Boog
laying low
Boog's Avatar
"herky jerky" and hard to drive sounds an awful lot like others who have found their steering center link was installed backwards. Your alignment shop might not catch it. Post up a pic below the bumper showing a good view of the center link and tie rods and maybe we can verify yours is on right.
That looks like a fairly new steering sector and they don't wear out quickly.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-05-2017, 09:14 PM   #4
Bigdav160
Bigdav160's Avatar
Plus the new CPP box and hoses
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-05-2017, 10:32 PM   #5
Oregon 1967 GMC
I was thinking it was pretty bad luck to have a bad box already as well. I didn't think of putting the center link backwards, thought it only went one way to fit. Maybe you can tell by the pics but it's hard to see.
Hey man
Old 04-05-2017, 11:05 PM   #6
RodnRudy
RodnRudy's Avatar
Yep, it's on backwards, the grease jerks on the tie rod end go to the rear of the link, castle nuts to the front.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 04-05-2017, 11:55 PM   #7
dmjlambert
dmjlambert's Avatar
It's like deja vu all over again...
http://67-72chevytrucks.com/vboard/s...d.php?t=730496
Old 04-06-2017, 12:01 AM   #8
Metaldoc
Metaldoc's Avatar
On backwards. I put 90 deg. grease fittings on the inner tie rods.
Metaldoc is offline   Reply With Quote
Old 04-06-2017, 12:22 AM   #9
kwmech
And torque down the sector shaft nut, looks loose in the photo
Old 04-06-2017, 09:28 AM   #10
Oregon 1967 GMC
Well I feel like a dummy. Thanks to you guys I'll go out this morning and get it right and take it back for alignment. I feel ignorant already so I might as well ask where is the sector shaft nut?
Hey man
Old 04-06-2017, 09:54 AM   #11
midniteblues
midniteblues's Avatar
It's the big nut that attaches the arm on the bottom of the steering box. Make it tight.
Too easy to do this should be some sorta sticky
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 04-06-2017, 09:59 AM   #12
Oregon 1967 GMC
Copy that midniteblues. Thanks mucho!
Hey man
Old 04-06-2017, 10:01 AM   #13
Oregon 1967 GMC
So it looks like I'll have to totally disconnect the center link and flip it around and put tie rods in the right way. Check check double check! Thanks again everybody.
Hey man
Old 04-06-2017, 10:09 AM   #14
tjc
tjc's Avatar
great call on center link
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 04-06-2017, 10:10 AM   #15
midniteblues
With alot of these truck going through disk brake and suspention upgrades.
And because it's easy and looks right too install that center link backwards it's happening quite often.
It's been asked alot here lately.
Once you get that link flipped you'll be set for some smooth sailing then.
Old 04-06-2017, 10:16 AM   #16
midniteblues
He ain't ****tin, take a close look at the nut and lock washer in this pic!
Old 04-06-2017, 10:24 AM   #17
Oregon 1967 GMC
Yuuuup! I'll tighten that bad boy up this morning.
Hey man
Old 04-06-2017, 12:01 PM   #18
randy500
Its good to hear the steering box is tight, rebuilds are always too loose, I want to buy one of those CPP boxes, now I will....
Too bad those dummies at the shop cant see that the center link is installed backwards, chevy only had that arrangement for over 30 years, I think the newer trucks still use it, idiots!!
randy500 is offline   Reply With Quote
Old 04-06-2017, 12:03 PM   #19
randy500
I will still go to les schwab for free flat tire repair....
Old 04-06-2017, 12:30 PM   #20
68is4me
68is4me's Avatar
That's kind of harsh, These trucks are almost 50 years old. The guy doing the alignment is probably half that in age. They are easy to get installed incorrectly if you don't work on them every day and I wouldn't be upset at the shop.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 04-06-2017, 01:49 PM   #21
randy500
Its a very common type of steering system that every mechanic should be familiar with and in use on current vehicles or at least into the 2000's. Made in front and rear steer designs that always are arranged in the same fashion...a straight line between the tires for the tie rod ends and center link. They also could have walked out into any parking lot and looked under a vehicle and noticed the improper installation...or looked in a repair manual or even online. Problem is the shop and the untrained mechanics.
They should have troubleshooted the system instead of jumping to the conclusion the box was "too tight" that steering box is uncommon (by appearance, not design) and they assumed it was the problem. I'm sure the owner explained it was all new, etc. A good mechanic should ask, what was changed, etc to see what could have been done wrong.
These untrained "mechanics" are parts changers and not mechanics.
Old 04-06-2017, 02:17 PM   #22
kwmech
AGREED!! Most of the "alignment techs" just spent a certain amount of hours at school just learning how the machine works. No real practical knowledge of how alignment and suspension works, ask them about ackerman angle and get a blank stare.
In fact that is exactly what a driver is experiencing when the centerlink is installed backwards. Ackerman all fubar'd... among other things
Old 04-06-2017, 02:54 PM   #23
68is4me
68is4me's Avatar
Not disagreeing with anybody, but calling them idiots?
I don't think our shop would have even caught that one. Our techs basically work on 2008 and newer stuff and being from MN almost everything is 4wd. Our older techs, which I am sure would have caught that, but they get paid way too much to due the alignments. The older techs are doing the involved stuff like motor and tranny rebuilds. The one's doing alignments are in the 20 and 30 thirty's which have probably never done alignment's on an old 2wd system. I just like to stick up for the shop's with not being there personally.
But anyway, sorry to the OP for getting of track. At least it is a cheap easy fix.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 04-06-2017, 06:06 PM   #24
Oregon 1967 GMC
I'm happy that it can be identified here and I don't blame anyone but me. My experience has been that some of the younger guys either get intimidated by the age of the truck or really interested and inquisitive. I think I had the former, plus they're leery about the work you've done, don't blame them. Had to go get dirt for spousal unit so I'm headed out to garage now. I'll let you know, the "Smooth Sailing" comment has got me motivated.
I'm definitely taking it back to Les Schwab
Hey man
Old 04-06-2017, 09:45 PM   #25
dmjlambert
dmjlambert's Avatar
The threads where this problem is encountered have pictures showing it put together backwards, but then they don't have a follow up picture later showing the same truck put together corrected. That would be nice to see.
