Old 01-12-2017, 01:09 PM   #1
Noxin
1973-1980 side molding clips
So on a 1979 c10 with the 1" side molding trim. Ive removed the bedside trim and there are two clips that look like and H. I broke them both thinking LMC had what I needed and turns out the clips they sell look nothing like the one that were on the truck, nor do LMCs work in my opinion. Ive tried searching this subjust on here, online, parts, ebay, images. With almost no luck.
I have seen on picture of the trim and hardware on another site and the clip was in the picture but I cant find these little pos things anywhere.
Noxin is offline   Reply With Quote
Old 01-12-2017, 02:23 PM   #2
TKCR
TKCR's Avatar
Re: 1973-1980 side molding clips
You'll need to post a pic of what you have
Old 01-12-2017, 02:27 PM   #3
TKCR
TKCR's Avatar
One place to look:
http://www.clipsandfasteners.com/category_s/761.htm
But not knowing what exactly your looking for, I can't be much help, in the case I have seen it before.
Old 01-12-2017, 04:49 PM   #4
Noxin
its the second clip looks like an H, has a pinch style clip on the back. Only picture in the world wide web of that little _____.
Old 01-12-2017, 05:02 PM   #5
75C10
The H shaped pieces are for the longer upper molding with one being located at the front of the upper molding and the second located about 2/3 of the way down the same molding to the rear. These are a push style of clip. My recent experience with the LMC clips are that they are poor in construction and shouldn't be used. My push in clips were not tempered correctly and just bent without holding the molding in place. I elected to not use them and used extra tape type clips. You may not have this option if you already have the holes in the box sides. The adhesive tape that comes with the clips is unreliable and should be changed for fresh two sided tape. The clips are fine, the tape not so much. The other clip (#1 in your picture) proved to be also poorly constructed and I found the self tapping nuts over powered the stud allowing it to spin. This made removal challenging. I could not locally source the correct clips and reused original clips found from a parts truck and/or your favourite pick n pull.
The replacement clips that comes with the moldings were over all unsuitable and required either additional effort (tape replacement) or complete changeout. Go find the clips you need from a donor. Even rusty original clips would work better than the replacements.
75C10 is offline   Reply With Quote
Old 01-12-2017, 05:19 PM   #6
Noxin
I understand all of that. The truck was repainted 2 years ago and the tape didn't stick on the truck, so I removed the worst one on the side upper bed and I broke the two clips because I didn't care. However now those two clips are impossible to find. LMC clips are way off not even for the same truck imo.
There are some plastic clips for rockers on impalas that may work on ebay which would same me having to clear the new clips as the ones on there now all bleed rust down the paint after it rains....
I just need to find the clips for now. Yes the truck has holes and im not fixing that I just want to go back with the same clips and not some spring loaded crap clip I got from LMC.
Old 01-12-2017, 07:54 PM   #7
UKNOWME
UKNOWME's Avatar
I'll try to look this weekend. I have a whole bag of retainers for those moldings from a kit I used. They may be the same as LMC but it doesn't hurt to check. You need 2?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-12-2017, 10:39 PM   #8
Noxin
Yes just 2. The clips LMC sent for a 79 I see being used on pre 73s but have no clue how they would work on 73-80 trims and those clips are not seen in the pic I sent....? Why LMC sells them for 73-80?
Old 01-13-2017, 10:59 AM   #9
Noxin
So who has the better clips for the molding besides going to a junk yard?
Old 01-19-2017, 11:28 PM   #10
UKNOWME
UKNOWME's Avatar
These??
1964 Chevy c10
Old 01-24-2017, 09:28 AM   #11
solidaxel
solidaxel's Avatar
My 78 needs these also, where did you find them?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-24-2017, 10:22 AM   #12
UKNOWME
UKNOWME's Avatar
I had them leftover from my build.
1964 Chevy c10
Old 01-24-2017, 11:12 AM   #13
1774btcrew
1774btcrew's Avatar
I would suggest used. It seems like the aftermarket ones tend to bend. I know the used ones are new and shiny but they clean up easy and aren't hard to find
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 04-24-2017, 12:47 PM   #14
phillipm
Originally Posted by UKNOWME View Post
These??
Anyone know what size hole these clips are supposed to go into?? They just seem to bend and won't really go in.
