Old 10-20-2003, 12:24 AM   #1
sixty8chev
The Sauz
sixty8chev's Avatar
Brake Problems????
OK its been a great weekend being covered in brake fluid and goin to the parts store and now i'm just frustrated.
I decided my brakes were feelin a bit squishy and ended up breaking off a bleeder, that was friday night, now I have new wheel cylinders on the rear, new flex lines on the front and a brake system full of new fluid from being bled about 10 times
and my pedals worse then when i started,
I pump it about three times and then it works like it should when the trucks goin forward BUT
put er in reverse and it works fine,
all my shoes are in right, no fluid leaks, the only thing that hasn't been replaced in the brake system in the last year is the master cylinder and hard lines.
So ......... any suggestions
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
