Old 05-04-2017, 06:21 AM   #1
riz
linkage issue .... please help
I put a 2" body lift in my K5 Blazer and welded in the piece that comes with the kit to extend the linkage but now it won't go into park smoothly.... I have to really make sure I have it in park or else it will lunge into reverse if i rev the engine....... how do I adjust the linkage so it will go into all the gears solid?
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 05-04-2017, 02:20 PM   #2
abig84
abig84's Avatar
Re: linkage issue .... please help
its been so long since ive done it but i know theres like a half inch bolt somewhere on that rod, either at the trans side or up under the hood. basically you want to losen that bolt then make sure your shifter is directly in park then manually put the transmission in park and see if that works and adjust a hair up and down if needed
abig84 is offline   Reply With Quote
Old 05-05-2017, 07:43 AM   #3
riz
Thanks, I'll try it today. I need to fix it before it kills somebody.
RIZ
81 C10 short box
82 K5 Blazer
Old 05-05-2017, 02:36 PM   #4
abig84
abig84's Avatar
yeah i had a old k5 blazer that was like that had to really jam it in gear. at the job i had at the time i always parked in front of this old junk car and a few times it did roll into it
