TH350 to LS 6.0. where does the kick down cable and vacuum hook to?
Swapping a LS 6.0 into my 72 K10. Is there a bracket for hooking the TH350 kick down cable up to the throttle? Where should I hook the vacuum for Tranny to? (drive by cable motor). Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
Re: TH350 to LS 6.0. where does the kick down cable and vacuum hook to?
I had a th400, so I can only answer the vacuum question, but I used the brake booster line off the back of the intake for vacuum. Works just fine.
![]() Join Date: Dec 2012
The kickdown cable....Your probably going to have to connect it to the throttle cable somewhere
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
could you explain that please? I have a th350 and will doing the same thing. Did you take the hose from the brake booster, connect to it somehow, or is there another hose you are referring to?
#5 | |
Hopefully this helps, if not, feel free to ask again for more clarification |
I haven't hooked up the cable yet...but I have read you can use a longer one and connect it to the throttle..will post when I do figure it out.
I ran the vaccum hose from the ls1 intake to my brake booster. My hose still had the same connection on the brake booster end that popped right into the booster. I have a trailblazer ss/07+intake here that has the same hose on it as well. The 99-06 truck vacuum hose should also work this same way.
Maybe you could T into this one for the trans
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
#10 | |
Punished, you figure out what you going to do to connect the kick down cable?
I am running a 4l80e, I don't have to worry about it haha
Got it. Thanks anyway!
