Old 05-16-2017, 04:22 PM   #1
1968_K20_4x4
Turn Signal Cancel? (Not the springs!)
Hey all,
Trying to fix my turn signal. It cancels properly when making a right turn, but will not cancel when turning left. I had read that it could be the little round springs but when I checked they were both there and working fine. What do I try next? Im thinking replace my turn signal canceling cam... mine has slight wear marks in the plastic and I am wondering if it has worn down enough to cause it to stop working properly. Any other suggestions? The truck is a 1968 and does NOT have tilt steering. Thanks!
1968_K20_4x4 is offline   Reply With Quote
Old 05-16-2017, 07:20 PM   #2
truckster
truckster's Avatar
Re: Turn Signal Cancel? (Not the springs!)
Every time I've had one that doesn't cancel it's been the cam.
truckster is offline   Reply With Quote
Old 05-16-2017, 08:19 PM   #3
72LB
72LB's Avatar
Same here, I'd try the cam first.
72LB is offline   Reply With Quote
Old 05-19-2017, 10:44 AM   #4
1968_K20_4x4
Thanks guys for the advice. I ordered a new cam from Classic Industries so Ill try that out and hopefully it will fix the problem
