Old 05-18-2017, 12:53 PM   #1
NoNeck
NoNeck's Avatar
Fuel Line Bending Tip
After collapsing my share of metal tubing over the years I came up with a shade tree solution that worked for me. I had a length of braided accelerator cable left over from an earlier job. I inserted the cable into the full length of the fuel line that I was bending. The bends came out perfect and the cable was easy to pull out after all the bends were made.
I know there are other tricks out there for bending fuel/brake lines, but I really like this one.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 05-18-2017, 01:07 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thumbs up Re: Fuel Line Bending Tip
Smart!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-18-2017, 02:10 PM   #3
57larry
or you could use a tool that bends tubing
57larry is offline   Reply With Quote
Old 05-18-2017, 02:22 PM   #4
toolboxchev
Nice, follows the same principle of mandrel bending. I was borne on a farm, and it serves the necessity of the mother!
toolboxchev is offline   Reply With Quote
Old 05-18-2017, 02:39 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Pretty slick
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-18-2017, 02:47 PM   #6
Rolland
Great idea and easier and less messy than filling line with sand.
Rolland is offline   Reply With Quote
Old 05-18-2017, 03:05 PM   #7
fatbass
fatbass's Avatar
Great idea! Add it to this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=486889
'71 C/20 350/T350.
fatbass is online now   Reply With Quote
Old 05-18-2017, 04:24 PM   #8
cleszkie
cleszkie's Avatar
X2. I have never had an issue with collapsing steel brake or fuel line when I use my tubing bender tool.
cleszkie is offline   Reply With Quote
Old 05-18-2017, 06:58 PM   #9
NoNeck
NoNeck's Avatar
I use a tube bender that I bought from Summit Racing years ago. I have never been able to bend a very tight 90° without some form of tubing collapse. When using this method all of my bends stayed open and free flowing.
POP
Old 05-18-2017, 10:22 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
POP
That must be a better version than the one I bought at O'Reallys. Mine is a real POS that will kink a line in a heartbeat, unless you fiddle with it a lot. I've had better luck using a couple of box end wrenches.
~Steven
Simi Valley, CA
Old 05-18-2017, 10:29 PM   #11
In The Ten Ring
POP
I have the same tool (linked by a member here) and after a certain angle, all bends are kinked. The accelerator cable idea is one I may copy, thanks!
In The Ten Ring is offline   Reply With Quote
Old 05-18-2017, 11:23 PM   #12
Metaldoc
Metaldoc's Avatar
I've bent tube by filling with water, freeze it and bend it.
Metaldoc is offline   Reply With Quote
Old 05-18-2017, 11:33 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have a tubing bender made by Mac Tools. It is made out of a pretty tuff nylon material. Makes great bends with no kinks at all. Here is a 3/8" fuel line I bent up and had one bend well past 90 degrees.
Kind of a bad pic of the bender, but it's the only one I have on file here.
Fuel line.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-19-2017, 12:47 PM   #14
GRX
GRX's Avatar
Good simple solution.
Couple of mine are using Ni-Copp line that is extremely easy to bend. And when working with steel, use of a torch to anneal the line to eliminate work hardening from the production process. Makes bending & flaring much easier. Not good for coated lines of course.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 05-19-2017, 02:09 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
This is a great tip for someone with out a bender.
But bending tube is only as good as the bender you use.
Buy the best bender that you can afford.
(and flaring tool also)
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
