Old 05-09-2017, 02:40 PM   #1
rctrooper1
LS Swap front wiring / junction block
I am in the final stages of my LS Swap on my 70 C10. I will like to do some sort of upgrade and use a junction block. I am looking for ideas and pics as I am more of a see and do kind of guy. I have visited mad electrical site and read their articles but still will like to see how it can be upgraded.
any help is appreciated.
rctrooper1 is offline   Reply With Quote
Old 05-10-2017, 09:30 AM   #2
Jstock85
Re: LS Swap front wiring / junction block
Can you be more specific? What exactly are you looking to do?
Jstock85 is offline   Reply With Quote
Old 05-10-2017, 10:10 AM   #3
LS short box
What I've done in the past on a few LS swaps is run the main battery cable down to the starter. Then a heavy 6 gauge wire from the starter to the stud on the alternator. Then for a good 12 volt source a heavier gauge wire from the alternator to a isolated stud mounted where it best suited for the vehicle. Because I'm a bit paranoid I run an in-line fuse in that wire. I think it's a 40 amp maxi fuse.
Old 05-10-2017, 10:48 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My truck has a main fuse block (engine/tran), a body block (under the dash where my original was), and also a main +12v terminal underhood for anything that needs a 12v source.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-10-2017, 10:48 AM   #5
Jstock85
You fused the wire from the alt to the starter?
Old 05-10-2017, 11:11 AM   #6
rctrooper1
I am looking to do away with the original splice on the front driver's side and add a junction block. I'm thinking about having the alt power wire run to a junction block. I was wondering what you all have done and if you all can upload pics.
thanks again,
Joe.
Old 05-10-2017, 11:12 AM   #7
rctrooper1
any pics?
Old 05-10-2017, 11:16 AM   #8
LS short box
Not the wire from the starter to the alternator. The wire from the stud on the alternator to the isolated stud for 12 volt power I fuse that wire.
Old 05-10-2017, 11:21 AM   #9
Jstock85
ok I got ya
Old 05-10-2017, 07:17 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by rctrooper1 View Post
any pics?
About 2/3 of the way through my build. I forgot the password to my Photobucket account haha. If I can get logged in I'll post them.
Old 05-11-2017, 11:12 AM   #11
Tork?
Maybe one of these firewall junction blocks to bring power into the cab?
Tork? is offline   Reply With Quote
Old 05-11-2017, 11:39 AM   #12
rctrooper1
I am thinking of going with two of these. one on the front left side where the old regulator used to be and hook up the alternator wire to it and the other on the firewall passenger side for other accessories.
If any of you have pics, please post them up, looking for ideas.
thanks.
Old 05-11-2017, 01:00 PM   #13
JJH Jimmy
JJH Jimmy's Avatar
I used this.
http://www.racetronix.biz/itemdesc.a...JBLOCK-001&Tp=
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 05-11-2017, 01:40 PM   #14
Jstock85
I like that Jimmy. Good clean look!
Old 05-11-2017, 02:56 PM   #15
rctrooper1
Originally Posted by JJH Jimmy View Post
Very nice! thanks!
Old 05-11-2017, 11:42 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine used to be on the inner fender. Now its the same terminal, but located sideways into the old mounting holes from the inner fender. I don't have a pic of that version atm.
Old 05-13-2017, 11:27 PM   #17
t300
Like the clean look, thanks for posting the link!
t300 is offline   Reply With Quote
Old 05-19-2017, 03:54 PM   #18
68 C10 LSX
I used the under hood fuse/relay box from a 97 Ford explorer. Bought it from the junk yard with relays and fuses still in it and bolted it right in after wiring everything up. I'll snap a pic when I get home and post it. Super easy and makes forgetting which fuse and relay are for what not an issue.
68 C10 LSX is offline   Reply With Quote
