Old 05-17-2017, 07:29 PM   #1
Flying Hamster
Flying Hamster's Avatar
P0420...
Melted a plug wire - 2006 4.3 130K miles
loom came loose and wire cooked on the exhaust manifold.
replaced the wires, plugs and now I get P0420 - generic code for catalytic converter on bank 1 not meeting minimum standards.
Is it related? Will the fouled convertor burn clean or am I looking at new converter?
Should I go outside and throw rocks at the truck?
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 05-17-2017, 09:23 PM   #2
GM-power
GM-power's Avatar
Re: P0420...
You need a cat.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 05-18-2017, 09:17 AM   #3
Deer_hunter_088
Deer_hunter_088's Avatar
Re: P0420...
yup killed the cat. my s10 did this. theres ways to get past this without a new cat. but im sure you know em.
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 05-18-2017, 01:09 PM   #4
kwmech
Re: P0420...
Check the voltages of both the 02 sensors before you go throwing a few hundred dollars on a convertor. Maybe you knocked a small vac hose loose while changing the wires which would throw the voltages off
Old 05-18-2017, 03:25 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
Re: P0420...
You would get a P0171 and/or P0174 if there was a vacuum leak.
Lean codes will set before a catalyst efficiency code.
99% of the time, a P0420/P0430 is caused by a converter issue.
I think its converter time, especially since the OP had an issue that allowed unburned fuel to enter the converter.
95 S_Trucker is offline   Reply With Quote
Old 05-18-2017, 08:25 PM   #6
Flying Hamster
Re: P0420...
Well, the truck started sputtering above 3000 rpm, and then backfired loudly several times and resumed running normally. Cleared the light, it came back, and now at idle it sounds like someone rattling chains in a metal trash can. With the truck off, I can get a similar rattle from the convertor by smacking the exhaust...
Yeah, cat is dead.
Still thinking about the rocks.
Old 05-20-2017, 09:56 PM   #7
Pyro
Pyro's Avatar
Re: P0420...
If you melted a plug wire then that cylinder was likely not firing, which means it's unburned fuel would be going straight into the exhaust. The P0420 code would be normal for that situation, but I'm surprised you didn't get a misfire code as well. I'd clear the code and see if it comes back after putting some miles on it.
Pyro is offline   Reply With Quote
Old 05-27-2017, 10:02 AM   #8
Flying Hamster
Re: P0420...
Never got a lean/rich or misfire code. The truck started stumbling hard and I pulled over and checked, pulled the wires away from the manifold, separated them and drove home.
Swapped wires and the next couple days it would have trouble going much over 2500 rpm. Then, it backfired a couple times and now runs fine except the Idiot Light and an obnoxious rattle at idle from the cats. You can bang on the cats and duplicate the rattle, so I figure the cats melted down.
Old 05-28-2017, 08:44 PM   #9
Pyro
Pyro's Avatar
Re: P0420...
Yup sounds like they came apart. Only fix at that point is to replace them, unfortunately.
Old 08-06-2017, 09:59 AM   #10
Flying Hamster
Re: P0420...
O2 sensor head melted after the cat...
Must have gotten hot.
