Old 05-03-2018, 07:14 PM   #1
Project86
Purchasing headlight adjustment screws???
Where in the world can I order all 8 new headlight adjustment screws for an 89 blazer?
Project86 is offline   Reply With Quote
Old 05-03-2018, 07:46 PM   #2
kwmech
Re: Purchasing headlight adjustment screws???
http://www.lmctruck.com/icatalog/CSB/full.aspx?page=195
Basic stuff, get the whole thing ---screw and plastic #7
Old 05-03-2018, 08:44 PM   #3
Project86
Clicked on that part number hours ago and it's not available.
Old 05-03-2018, 09:59 PM   #4
franken
Auto parts stores typically have a red help section w/ odd parts such as door hinge pins/bushings and probably the HL adj. screws you're looking for.
I found some/all the parts are Dorman, googled it for you... 42119? If that's what you want they're as close as a parts store.
https://www.google.com/search?q=dorm...utf-8&oe=utf-8
Old 05-04-2018, 08:41 AM   #5
Project86
I had them look up the part numbers about a week ago they were unable to order the proper ones
The ones on the shelf they did have fit blazer s10s
Old 05-04-2018, 09:00 AM   #6
TKCR
TKCR's Avatar
have you tried here?
http://www.clipsandfasteners.com/Hea...lies-s/106.htm
Old 05-04-2018, 09:14 AM   #7
TKCR
TKCR's Avatar
I believe this is what you need
http://www.clipsandfasteners.com/Hea...M-p/a11243.htm
Old 05-04-2018, 10:06 AM   #8
Project86
I think that is! Thanks for the links
Old 05-05-2018, 04:39 PM   #9
Edahall
I eliminated the plastic and used a nut and washer from behind.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
