Fuel Sending Unit Ground Location?
Hello all,
Wondering if someone could help me out with this. I purchased an took over a friend's project. 1972 C-10. The previous owner had already mounted a new aluminum bed mount fuel tank. The sending unit which is already installed does not have a separate mounting point for the ground. My questions are: 1. Does it need a ground or is the tank bolted to the frame the "ground". 2. Should I install a ground wire beneath one of the 5 bolts on top of the sending unit as seen in the pic? or 3. Should I put the ground on the same mounting point as the sending unit wire beneath it. Thanks in advance for any help. |
#2 | |
The Older Generation
Re: Fuel Sending Unit Ground Location?
If the tank is mounted on rubber pads or straps with isolators you will need to use a ground wire. If the tank is bolted directly to the frame you may or may not have a ground, depending on how much paint is on the frame. I would just run a ground wire to one of the mounting bolts (between the tank and the head of the bolt) and clean the paint off around a hole in the frame and bolt it up. LockDoc
That's what I was leaning toward sir, just wanted some input from someone with more knowledge than me. Thank you
#4 | |
![]() ![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Old member
Just for good insurance run a wire off one of those mounting bolts over to a bare spot to the frame. This way you know you have a good ground.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6 | |
Not really. I just went through this yesterday on my '36 Ford Coupe. Whenever you are grounding to an area that is powder coated or a couple of coats of POR15 you cant rely on the grounding (internal and external star washers) to bite through it to bare metal. I removed the POR15 on the areas of my frame where I bolted the ground straps. I still use the star washers, but I want the metal clean. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-20-2017 at 09:29 AM. |
#7 | |
