Old 07-17-2017, 12:32 PM   #1
RodnRudy
RodnRudy's Avatar
Distributor length
I was in a discussion with a friend today and he asked me a simple question that I don't know the answer. Are all OEM GM SB distributors the same length? I'm talking about the bottom of the mounting flange to the end of the shaft. He said he thought some could be 1/2" shorter I don't think that's true. What say the experts out there?
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 07-17-2017, 12:46 PM   #2
b454rat
Re: Distributor length
All small block and big block are the same length as far as I can remember.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-17-2017, 01:00 PM   #3
61K10
61K10's Avatar
348 and 409 are different if i remember right.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-17-2017, 01:42 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The 348/409 are completely different animals.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-17-2017, 06:58 PM   #5
RodnRudy
RodnRudy's Avatar
Thanks guys for the help
Phil
Old 07-17-2017, 09:53 PM   #6
raceman6135
Dino burner
raceman6135's Avatar
Medium and heavy duty tall deck 366 and 427 cubic inch big blocks used a longer distributor than Gen I small block and Mark IV big block engines.
raceman6135 is offline   Reply With Quote
Old 07-18-2017, 06:14 AM   #7
b454rat
TD uses the same length but there is something different. But a longer one is needed if using spacers to run an aftermarket intake.
Old 07-18-2017, 04:59 PM   #8
68Gold/white
Yes, 366 and 427 tall deck dist's are same length as small blocks and big blocks.
IF, IF you use spacers on a tall deck engine with a conventional low deck 396, 427, 454 intake you need a dist. with a movable collar, to correctly place dist gear in correct place on cam gear.
There's some other weird stuff like the earliest small blocks had a different passage setup, that's the channel at the bottom of the dist housing, just above the gear. The first year or two of the tall decks were gear to gear timing setups, no chain. The dist gear was obviously different on these...
There are a few more, but they are REALLY odd and not common
348's and 409's are cool engines, but I'd want to have a bunch of extra parts for them, if I was running one. Some of the every day parts for them are way hard to find.....
68Gold/white is offline   Reply With Quote
Old 07-19-2017, 01:14 PM   #9
Marv D
Registered Truck Offender
Marv D's Avatar
Key words "OEM" and "SB"
Correct answer,,, YES
Be it points or HEI, the length from the flange that sits on the intake, to the tip of the oil pump drive is the same for OEM stock distributors.
As mentioned there was some oiling differences in the 265 block with no oil filter, but the distributor length was the same.
The rub comes in (aside from those mentioned tall deck motors) with aftermarket SBC intakes and odd oil pump set-up's, + massive decking and milling changes the height of the intake above the oil pump. A distributor with an adjustable collar is the simple fix.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
