Old 08-23-2017, 04:46 AM   #1
Nils
Nils's Avatar
1966 C10 Fuel Line Size
Hello,
now I make/ install the new Fuel Line with the Fuel Filters, Fuel Pump, Gas Tank und the Carb (Edelbrock Performer 500cfm).
I would like to put a steel hard line in 5/16 from the Gas Tank to the First Fuel Filter Canister Style with 3/8 NPT inlet and outlet under the Cab. From the Filter with 5/16 Hard Line to the Fuel Pump (3/8 NPT inlet/ outlet). From the Fuel Pump with a 5/16 Hard Line to the second Fuel Filter and to the Carb with 3/8 Inlet.
Now my Question. Is it better to use compleate 3/8 Steel line from the Gas Tank and not 5/16 ? The Problem ist, that the Tank Sendig unit have a 5/16 Line and thread.
What is the best option with the Edelbrock Performer 500cfm. The old Carb was a 2 Barrel.
Thank you all verry verry much.
Greatings from Germany
Nils
Nils is offline   Reply With Quote
Old 08-23-2017, 05:05 AM   #2
Nils
Nils's Avatar
Re: 1966 C10 Fuel Line Size
By the way. The Engine is a 283 c.i. V8
Old 08-23-2017, 06:41 AM   #3
PGSigns
PGSigns's Avatar
5/16 is fine. Also that carb needs a fuel pressure regulator as they dont like much more than 4 psi. Some will take 5 but my last two eldelbrocks like 4 better.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-23-2017, 01:04 PM   #4
Nils
Nils's Avatar
Jimmy
Thank you verry much Jimmy.
Which fuel pressure regulator do you prefere?
