Old 08-31-2017, 06:33 AM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
AFR Heads / Be-Aware
Be aware: I orderd a set of AFR 180cc SBC Eliminator Street Heads 0916. The heads comes standard with AFR 8017 valve springs. These springs are used with a hydraulic Roller cams (without getting in to numbers). Im still running Hydralic flat tappet cams in GEN 1 SBC, which require a different spring set up, AFR 8020. I only realized this when I was reading the Q/A on Summit website for 0916 heads. I called AFR this morning and they confirmed that a spring change was necessary. Well $310.00 later in parts, looks like I will be changing springs.
I did ask the AFR tech if could order a set of heads with 8020 springs and he stated I could but, they would have be ordered directly for AFR and would take additional 2-3 weeks.
Maybe I should have researched a little more, but it still gets me PO'd!
**This is not finger pointing, just sharing my experience**
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-31-2017, 09:08 AM   #2
geezer#99
geezer#99's Avatar
Re: AFR Heads / Be-Aware
Interesting!!
So what exactly is the difference?
Old 08-31-2017, 11:40 PM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Geezer, I will attach the AFR document which will show the difference in the springs, basically a AFR-8017 spring seat pressure is 140lbs, Hydraulic Roller Cam. AFR-8020 spring seat pressure is 125lbs, Hydraulic Flat Tappet Cam. I have/going to run Lunati 10120701, Flat Tappet with this rebuild. Not so much the spring change, but the cost. AFR tech informed me that I had to buy springs, retainers, spring locaters, valve locks and just in case, seals. Nothing interchanged due to the size spring, I believe valve locks and seals were unnecessary. First time I've worked on AFR heads, so better safe than waiting for more small parts.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 09-01-2017, 09:45 AM   #4
geezer#99
geezer#99's Avatar
Thank you!
Good info!!
