Finding the Wheel - 17" 8 Lug Poverty
i am not having much luck finding something similar to this in 17". wheel vintique is one place i looked and several others. anyone have any good leads? thanks! |
![]() ![]() Join Date: May 2015
Re: Finding the Wheel - 17" 8 Lug Poverty
16s are plentiful in wheels like those. .not finding it in 17...any reason a 16 wouldn't work?
closest thing I could find was a dodge 17in... Last edited by mongocanfly; 09-12-2017 at 11:47 PM. |
#3 | |
Posted via Mobile Device |
Cragar makes a soft 8 and d window n 17s and 8 lug.And what are the axles from ?Because there is 2 different 8 lug patterns and if its a 4x4 the hub bore size can very from brands like ford chevy and dodge use different sizes.
1978 Ford hp Dana 60 and 1996 Dana 80. Not interested in soft 8's or d holes. The 60 will be restudded to match the larger 80 studs too.
I like the classic look, aftermarket wheel not so much. Posted via Mobile Device |
If you want steel 17s that look factory those dodge rims are it in your lug pattern,If you want alloy there the h2 rims,Or a set like these http://www.ebay.com/itm/CHEVY-4X4-SR...NYyGlL&vxp=mtr If you changed it over to the metric lug pattern your options go a lot bigger for oem rims from the big 3.
Collector of Projects
check with
http://www.stocktonwheel.com/heavy_duty.html |
#8 | |
![]() Join Date: Oct 2009
Good Lord avoid Stockton.. I had a horrible experience with them.
here is what i did for stock look with my newer twist to it .
black d-window rims . blasted and redone white . conversion lug nuts to hold black plastic nut covers . these hold drw rear center caps from 88-98 body style trucks . granted i did 16x10 rims . . . but same ideas . and 1 old gm orignal for refrence of my idea/ twist on it .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Those turned out nice. I've only seen em in black before.
those turned out nice sweetk...
i hate the black rim faze . . . why they went white brand new out of the box from black .
#15 |
I've talked to wheel vintiques on the phone about 17" wheels.they are not real interested in making them. I'm wondering if we started a thread here about it and got a bunch of people that wanted them, if they might start building them? I would love a set on my crewcab, and my 76 pathfinder van.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#16 |
stockton quoted about 1200 for a set of four 17 inch wheels to accept my k30 hub caps.
they take a 16" wheel center then a 17" barrel. make a ring spacer and weld the three pieces together. seems like a pain in the ass to make yourself so the price isnt far out of line for specialty work.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. |
#17 |
For what it's worth, Stockton just delivered a set of wheels after 3 weeks. Exactly how long they told me it would take.
#18 |
6>8 Plugless........
![]() Join Date: Sep 2007
Did you get the 17s? I called a while ago and they wouldn't even give me a quote and said they wouldn't make them. I plan to use the dodge steel 17" wheels if I ever get to working on the truck again.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#19 |
I would rather get detroits 18" wheels, than stockton. 1K for a set and you can get clips to run hubcabs on them.
#20 |
He has a 4x4 would those Detroit rims have a hub bore big enough ?
#21 |
No these were for a customer at the shop. Not my wheels unfortunately
#22 |
Sorry slow reply. Ordered pc'ed vette rally wheels from them a logn time ago - they arrived flashed over with surface rust in a lot of areas (yes, I had the same reaction...) and, somehow, that was my fault(!) The issue was they hadn't fully pc'ed properly and all the freshly blasted areas that didn't receive the pc were rusted - was almost like the wheels just got a cursory shot and there were a lot of missed spots, especially at the wheel/center joint. Several back and forth shippings and they never really corrected the issue - I ended up treating and touching up with paint. It was just shoddy work to begin with and horrible customer service after the fact.
