Old 09-30-2017, 06:57 PM   #1
georgieboy
Angry Freeze plugs on rear of 292
Today I was replacing the freeze plugs on my 292. 2 freeze plugs are located on rear of eng. behind the flywheel. I proceeded to remove them and one covered the rear of the cam and was almost impossible to get out. I left some punch marks on what ever is in there. Have I done great damage to my engine?
georgieboy is offline   Reply With Quote
Old 09-30-2017, 07:41 PM   #2
johnwaynejeep
Re: Freeze plugs on rear of 292
Freeze plugs cover up water jackets which is why they call them freeze plugs. Really those are "Core Plugs" used to dump sand out of the engine block after casting the block.
The reason I mention this is that freeze plugs tap into water jackets and there is little you can damage as long as you're not drilling through the plug and accidentally drill through the block, which has happened.
On the other hand, permanently installed plugs can also cover machining access holes and if those components are damaged could be very bad.
Post a picture and we can tell you if the plug you're talking about is a typical freeze plug or a machining plug.
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
Old 09-30-2017, 09:19 PM   #3
georgieboy
I don't know how to post photos yet.
Old 10-02-2017, 01:27 AM   #4
johnwaynejeep
You'll need to upload the photo to a web site that will host the photo, like photobucket. When you reply to this post, click on the icon at the top of the text screen that looks like a mountain with a moon rising over it. Enter the web link into the pop up that opens and it will post the picture in your reply.
Kind of a pain in the neck, I thought it would be easier then that.
Sorry man
Robert
Pacific Grove, CA
Old 10-02-2017, 10:00 AM   #5
georgieboy
Well, I googled it as I should have first and yes, it is a machine plug. Thinking it was to a water jacket, I had a hard time getting it out( should have googled first). With this new information, I looked again and believe I have damaged the rear cam bearing and possibly the rear of the cam. Ignorance plus too much exuburance gets expensive. I got pretty rough getting it out.now I have to learn to post photos or just replace the cam and bearings.Thanks for the info. Dumb ass George
Old 10-02-2017, 08:52 PM   #6
johnwaynejeep
It would be a good opportunity to do an engine rebuild. It'll cost about $1000 in machining and an overhaul kit. Aside from that you can do everything yourself with hand tools a balancer puller and a piston ring compressor.
Good luck
Robert
Robert
Pacific Grove, CA
Old 10-03-2017, 12:12 AM   #7
georgieboy
Thanks to you for helping me figure it out. A friend came by and got the cam out. I need new cam,cam bearings, timing gears,lifters, plug seals. Already had gasket set. 12 bolt had everything I needed. By the way if you're interested, Tom Langdon of Stovebolt Motor Co. has stopped dealing with later sixes such as 194, 230, 250, &292. I guess he's slowing down or something. Hate to see him go. He ran a good business. Thanks again
