Active Member
![]() Join Date: Oct 2017
Full Time Dana 60al
I just acquired a 1977 Chevy K30 SRW standard cab from Arizona. According to the info in the glove box it was originally bought in New Mexico and spent all of its life in Arizona, as far as I can tell it still retains the original 350 and is a factory 4-speed truck with 205 case. The body is very solid. The cab and frame are in great condition with very little outer cab corner work needing to be done. Front fenders and hood are junk. It must have sat under a pine tree at one time and the needles worked there way down to start the rotting process. This truck also came with factory bucket seats that I need to track down. Enough about the truck. I always thought that if the truck had a part time transfer case and manual trans it should have lockouts on the axle.
I bought it with some cheap lockouts on it but they did not work correctly and were very loose in the hub. I bought some original lockouts on eBay. I went to install them and there was no outer groove in the hub to hold the lockout body in the hub. It was smooth all the way out. I looked in my parts book and it did not show a locking hub break down for 77-78 trucks with Dana 60 just the full time drive gear and dust cap. I checked my later parts book and it shows the lockouts for the Dana 60's coming into view in 1979. I checked my '79 GMC and sure enough it had the groove at the outside of the hub for the snap ring. Did 77-78 one ton trucks come with full time hubs regardless of wheather it was a manual or auto trans? Thanks for any help. Posted via Mobile Device |
Re: Full Time Dana 60al
I think your truck MAY have originally came with a NP 203 which might explain the hubs on the front.
Does the shift indicator plate on the trans hump have the correct pattern for your 205? |
Active Member
#4 | |
Active Member
Very interesting. It sounds like GM didn't have faith in any lockout hubs for a 1 ton truck in 77 and 78. I have never seen a 77 K30 in person so I always considered them kinda rare. I wonder what was holding your original cheap hubs in there?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#6 | |
Active Member
![]() Join Date: Jan 2015
Nice truck!! To bad your not close to Frederick Maryland there is a pair of Nos fenders and a nos pass door on Frederick Craigslist for $500.00 for the fenders and $300.00 for the door
#8 | |
Active Member
i have a original 77k30 . 34k miles on it . i could go pull a full time drive slug cap and check for the grove for you tho .
easy to spot early trucks . pass side king pin cap on dana 60 is cast iron NOT tin . first year or so only . front spring hangers for rear springs were 2wd short . this gets you a factory 3" block WITH bump stop ear in the rear to make up the difference . mine was a th400/203 truck and had a 2 piece drive shaft with carrier bearing . front shaft was around a foot or so . . . if i recall been years but i do think they didnt have the grove . would be easy for someone to chuck up in a lathe and cut it in tho .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#10 | |
Active Member
pop us up a pic of the back of the transfer case .
help you dial it all in . to know what ya got . another true tell of a k30 in square body is rear shock frame mounts are inside the frame rails . 1/2 - 3/4 tons got them outside unless the light duty 3/4 ton crew cab they are just under sprung 1tons. your rpo code sheet shows gov-loc rear posi . and the tire size might be the rarish 9.75" wide 16.5 rims . have to measure to be sure .
#12 | |
Active Member
I have a nice rust free and original paint 79 C/20 Silverado I've been thinking of putting a 85 K/30 frame and running gear under but not sure yet
#14 | |
Active Member
#15 |
I never had a 77 K/30 but I had a 78 K/30 cab and chassis here's a pic of it
#16 |
And my 68 K/30 (was a C/30 2wd)
#17 |
I also have a nice 73-80 tailgate band if interested I can post pics
#18 | |
Active Member
#19 |
Ok will do I actually have two
#20 |
Here's the best of the two I have
#21 |
Another
#22 |
Has a small decal on the end
#23 |
I also have a pair of nos (no box) Silverado 30 fender emblems I bought here on the parts board awhile back I'd sell for what I paid for them
#24 | |
Active Member
#25 |
It has two little scratches about the size of a dime and I don't know what you paid for your fender emblems but I paid $310.00 shipped I'd take $125.00 plus shipping for the tailgate band
