Old 11-20-2017, 10:09 AM   #1
56weav
Cam change
Having researched the cam change question ,different answers can be found.
The question. Can one change the cam in a 1986 sbc gmc without removing the engine. If so can it be done with butchering the radiator support .
The reason one asks. The ceiling height of my garage is low and a cherry picker probably won’t have enough clearance to remove the engine Outside isn’t really an option it soon to be winter in Illinois and cold
Thank you for response
56weav is offline   Reply With Quote
Old 11-20-2017, 01:38 PM   #2
DieselSJ
Re: Cam change
Yes. You need to pull the radiator, A/C condenser, and probably the grill also.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 11-20-2017, 03:57 PM   #3
akart
Re: Cam change
I did my cam change w/the engine in and yes you do have to bash/bend the radiator support a bit. Bend it nice and it will bend back,not that bad. Oh and w/the radiator removed you can climb right in there for the valve adjustments.
A lot easier than removing the engine.
akart is offline   Reply With Quote
Old 11-22-2017, 02:38 AM   #4
akart
Re: Cam change
Forgot to add that my truck is a 1986 also.
Old 11-22-2017, 04:29 PM   #5
56weav
Re: Cam change
Thank you
I figured I could but needed a little confirmation
I’ll start my build soon gm 113 aluminum heads , 69 350 exhaust manifolds, aluminum intake, and a new cam and new rebuilt carb.
With the right head gasket it will give her 9 to 1 compression
It should solve the “ go faster option” on the interstate
Old 11-24-2017, 12:14 AM   #6
raceman6135
Dino burner
raceman6135's Avatar
Re: Cam change
When I replaced my cam and lifters, I removed the motor mount through bolts (one on the driver's side, and one on the passenger's side), lifted the engine a bit, and moved it to the side enough for the camshaft to clear the centre radiator support.
On one vehicle, I also had to remove the 2 bolts that go through the transmission crossmember into the rubber transmission mount. When I moved the front of the engine toward the passenger's side in order to get the camshaft out, the transmission could rotate just a bit on the crossmember to afford me lots of room.
raceman6135 is offline   Reply With Quote
Old 11-24-2017, 12:21 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
Re: Cam change
Pull the front clip
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
