Old 11-27-2017, 10:34 PM   #1
andrewpclayton
andrewpclayton's Avatar
Where does LMC Cigarette lighter blue wire plug into?
I got it working with the red but the blue connector which it says goes to the fuse panel doesn’t have a spot for a connector like this
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 11-27-2017, 10:38 PM   #2
Hotcorner
Hotcorner's Avatar
Re: Where does LMC Cigarette lighter blue wire plug into?
That looks like what goes on the backside of the socket.
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 11-27-2017, 11:45 PM   #3
andrewpclayton
It’s super long though and I don’t see a spot for it to go.. weird
Old 11-28-2017, 01:28 AM   #4
Rufas
Rufas's Avatar
That's correct.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 11-28-2017, 07:05 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Where does LMC Cigarette lighter blue wire plug into?
Is this what you have?
The blue wire should go to your lights so that at night when you have lights on it will light up. More than likely you will have to cut the wire and use a crimp connector. I would tie into the heater/AC light bulb.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-28-2017, 08:06 AM   #6
rsavage
rsavage's Avatar
For the light, I believe. There should be a female connector available for it if I remember correctly (no guarantee of that though).
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-28-2017, 12:17 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
See my post in the electric forum. VV
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
