Old 11-22-2017, 10:15 PM   #1
Marcus4800
Clutch & Pressure Plate?
I have 63 C10 with a 230 engine. I need to replace the pressure plate. The one that's in it is the 10" clutch and pressure. The pressure plate has a bunch of those finger things in the center of it and someone told me a 3 finger is better. The only 3 fingers I can find start at 11" to 12". Can I replace my 10" with either a 11 or 12 inch?????
Marcus4800 is offline   Reply With Quote
Old 11-22-2017, 10:51 PM   #2
Killer Bee
Killer Bee's Avatar
Re: Clutch & Pressure Plate?
three arm plates borg and beck style
the one you have is diaphragm style
borg and beck are often touted as better performance however high performance models of each are bountiful..
for good performance, drivability, and economy, I'd look at centerforce..
put one in my last manual and it was a measurable upgrade..
good luck!
Old 11-22-2017, 11:59 PM   #3
Captainfab
60-66 Nut
Behind a 230 a 10" diaphram style will be just fine. And easier pedal pressure too.
Old 11-23-2017, 01:12 PM   #4
Wrenchbender Ret
The diaphragm clutch is much better then the old 3 finger type.
George
Wrenchbender Ret is offline   Reply With Quote
Old 11-23-2017, 03:12 PM   #5
AcampoDave
AcampoDave's Avatar
Yep, 3 finger clutches are for those who love the challenge of keeping the pedal depressed thru a long light. I had one and hated it. I swapped it for the diaphragm style. Much better.
AcampoDave is offline   Reply With Quote
Old 11-23-2017, 06:39 PM   #6
vince1
Some diaphragm clutches as I remember have a raised portion close to the center where the throwout bearing rides. Those will take a flat bearing. If the fingers are straight all the way then that pressure plate takes a bearing with a convex bearing surface. Just be sure you get the right bearing for the corresponding plate. Could be I am thinking on other brands here though. Diaphragm clutches are way smoother in my experience.
vince1 is offline   Reply With Quote
Old 11-23-2017, 06:42 PM   #7
vince1
Taking this a step further, what would he do if a 350 was in its future?
Old 11-23-2017, 06:51 PM   #8
geezer#99
geezer#99's Avatar
Actually, you mean short bearing with raised finger and long bearing with flat finger.
A 10 inch clutch will work with a 350 if needed.
The deciding factor is if his flywheel is dual drilled or not. Drilled for both a 10 and an 11 inch.
geezer#99 is online now   Reply With Quote
Old 11-24-2017, 09:46 AM   #9
Marcus4800
Thanks for all the help..... Good info
Old 11-27-2017, 01:02 PM   #10
rvrfoot
I drive my every day. I would go auto.
rvrfoot is offline   Reply With Quote
