Old 11-26-2017, 10:21 PM   #1
raidmagic
raidmagic's Avatar
Finally found my truck.
I've been looking for one for a while now and finally came across this one. Not crazy about the red wheels but it's a start. I'm pretty excited about it. 1965 It's got a hopped up 6 in it with a 4 barrel and split header to dual exhaust. Sounds pretty sweet. I'll run it around like this for a bit but it will end up with an LS1 I've got one sitting in the shop. It has a 3 on the tree. Anyone know what's involved to swap that to a super t 10? I have one of those laying around too. A 4 speed on the floor would be fun. Anyway here's a shot of it and I'm sure I'll be around asking more questions.
raidmagic is offline   Reply With Quote
Old 11-26-2017, 10:50 PM   #2
Blue666(2)
Re: Finally found my truck.
Nice truck!
Blue666(2) is offline   Reply With Quote
Old 11-26-2017, 10:54 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I wish you fun times with it. .
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-26-2017, 11:16 PM   #4
Blue666(2)
Check your research but the three speed should be the same length as the ST-10. Your speedo cable & the cross member should good. There could be a difference in the type of yoke at the tail shaft.
Cut a hole for your shifter and buy a boot & you'll be have fun with a four on the floor.
Old 11-26-2017, 11:18 PM   #5
Blue666(2)
This could be helpful. http://www.chevelles.com/forums/33-t...ie-lenght.html
Old 11-27-2017, 12:26 AM   #6
Captainfab
60-66 Nut
Looks like a nice truck to work with. That T10 will bolt up and hang off of the back of the bellhousing just like the 3 speed does. If your truck still has a bench seat, you will need a shifter stick for a '55-'57 Chevy that has a dogleg in it.
Old 11-27-2017, 02:50 PM   #7
rvrfoot
Enjoy it.
rvrfoot is offline   Reply With Quote
Old 11-27-2017, 10:46 PM   #8
raidmagic
raidmagic's Avatar
Thanks for the info on the trans swap. I'll be doing that soon. Today was my 1 day with a tag on it and able to drive it around. Damn the fuel smell in the cab is unbearable. I don't see any leaks either. Either way I ordered up a tank and am going to relocate it to the rear of the truck and see how that goes. Thanks for the kind words.
Old 11-27-2017, 11:26 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Fuel smell in the cab is common, best cure is a new sending unit gasket and tank filler neck tube. Never had any fumes in my 66 again, but I also converted to a frame tank.
Old 11-28-2017, 08:44 AM   #10
raidmagic
raidmagic's Avatar
I've ordered up some stuff to covert it should be here in a couple of days. It's so bad you can't be in the truck with the windows up. My old 66 wasn't this bad. At least I don't remember it being bad but that was a lot of years ago.
Old 11-28-2017, 01:45 PM   #11
dean jendro
Old and crusty
dean jendro's Avatar
Nice truck, good find!
65 Chevy long wide daily driver - SOLD!
64 Chevy Short Step LS
dean jendro is offline   Reply With Quote
Old 12-01-2017, 02:11 PM   #12
Magnimike1
The rubber that connects the tank with the outer filler neck is typically the culprit.
Magnimike1 is offline   Reply With Quote
Old 12-01-2017, 07:43 PM   #13
Mathew21
Mathew21's Avatar
Nice looking truck, Congrats!
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-01-2017, 08:22 PM   #14
DPowers
One foot in front of the other
DPowers's Avatar
Nice- what wheels you going with?
DPowers is offline   Reply With Quote
Old 12-01-2017, 08:23 PM   #15
Richard2112
Richard2112's Avatar
Nice lookin' truck.
Richard2112 is offline   Reply With Quote
Old 12-01-2017, 08:32 PM   #16
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Sweet truck!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-02-2017, 11:06 PM   #17
raidmagic
raidmagic's Avatar
Thanks everyone. I'm happy with it so far. I had to pull the whole fuel system and tear the carb down for all the trash in them but the new under bad tank will solve that issue.
Not sure yet. I have always wanted to put Convo Pro's on a car so I might go with those. Still a way off of putting new wheels on it. The clown wheels will have to do for a bit. I might repaint them though.
Old 12-03-2017, 01:33 PM   #18
yeah_yeah_na
Let us know how you get on with that fuel smell.
yeah_yeah_na is offline   Reply With Quote
Old 12-03-2017, 02:41 PM   #19
Bomp
Bomp's Avatar
Congrats on the truck.
Bomp is offline   Reply With Quote
Old 12-03-2017, 06:37 PM   #20
rvrfoot
Ask any questions we are here to help.
Old 12-03-2017, 10:29 PM   #21
raidmagic
raidmagic's Avatar
I stripped the whole fuel system out of the truck. Ran a new hard line to the rear of the truck. My new under bed tank should be here Wednesday. I'm sure the tank was the cause. Before I removed it it flat hurt to get in the truck. The fumes were terrible. Just going out to the shop now is so much better. I've got the tank sitting on the driveway. I'm going to throw a few gallons and see if it's seeping from the bottom seam or something. I don't know.
Old 12-03-2017, 10:33 PM   #22
rvrfoot
Dont smoke by it. lol
Old 12-04-2017, 02:51 AM   #23
Hollow65
Hollow65's Avatar
Nice rig
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 12-04-2017, 04:40 PM   #24
Android04
Android04's Avatar
Nice truck, enjoy.
Android04 is offline   Reply With Quote
