![]() Join Date: Feb 2012
Goodmark door question
I have a chance to buy two new 67-71goodmark doors that are new in box for 500. The Seller says he bought them in 05 or 06. So the question is were goodmark doors any good back then? I have read a lot about door quality being not so good a few years back but hoping someone could chime in with some good info. My oe doors are way to bad to repair and I think new doors would be the way to go
Posted via Mobile Device |
Moderator
![]() Join Date: Jun 2008
Re: Goodmark door question
I've heard of success stories with them, but for me, they were a headache. I had a set, but I couldn't get them squared up to both shut correctly while lining up with the body lines. I spent many frustrating hours messing with them before ultimately giving up. I found a set of OEM replacements and they hung perfectly the first attempt without any real effort.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
The Older Generation
I have a replacement drivers side door on my '72 Dually The previous owner fought with it when he had it and I worked on it off and on for 6 months or so and couldn't to get it to fit correctly. I don't know exactly how old the door is but I think it is one of the earlier stampings. I finally got it to fit halfway decent by re-cutting the door latch hole and moving the latch up 1/4-3/8 inch. It still isn't perfect but at least it will close all the way now. LockDoc
I think i am going to just buy other oe doors. I know they will fit perfect. I found some on craigslist but require a 10 hour round truip drive and do need some work but nothing as bad as my doors now. Thanks for the input
Funny... that was me with the doors. I saw this topic and knew it had to be my ad.
When we bought all that Goodmark stuff... it was the best in the business for aftermarket. I haven't seen any part (aftermarket or OEM) that passed my own standards for quality. Everything gets tweaked to the vehicle. We had heard that the dies for the fenders, doors and other parts have since wore out. LKQ has purchased Goodmark so we'll see if the name totally dissolves or not. The cab floor I installed this weekend is boxed as a Woodall. It's a pretty close fit. The adjustments needed could be due to a wore out cab. I'm using two Goodmark bedsides from 05/06. I haven't paired them up with the OEM bedfloor yet but the Goodmark sides were supposed to be the best back then too.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
#6 | |
See if you can find an old Chevy C40 or C50 farm truck around you some where. They are around, and the doors are the same except the front lower corner is cut off of them to clear the front fender. They are usually in pretty good shape because the trucks sit up so high. You might get lucky and find a tach dash in it too.... LockDoc
I recently purchased some of the new doors, boxed in Key Parts boxes from Cooper Restorations. They are actually pretty good. They fit in the opening, body lines match and they latch just fine. The gaps had to be fit by grinding / welding / filing which really is quite a bit of work, but not too difficult really. The only fit issue that I have is the contour of the door is a little flat compared to the fender. I tweeked the fender and added a fairly small amount of filler to the door to get the two to match.
![]() Join Date: Nov 2004
I would personally pass. I bought a set in 2004. The outside skin is thin, much thinner than OEM.
They finally addressed this issue by making the skin thicker on the doors a year or two ago, unfortunately how old someone's stock is could be hit or miss so the best way to tell is to buy a set in person. Gently push in on the middle of the door, if it moves easily like a modern car, I'd pass. The new thicker ones flex very little when you push on the middle, closer to OEM. This is a great idea. I'm fixing my factory doors that I kept to go back on the truck. I finished one door, one to go. Glad I saved them. I didn't have the tools or skill to fix them in 2004.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Back then is when repro doors were bad and Goodmark sells what everybody else sells, with their name put on it. I heard they are more piucky with what they'll accept to sell, but that is the only thing to put their quality over others. The thing is, with something like doors made wrong in multiple ways, they are all bad so Goodmark was selling the best junk. Those bedsides from Goodmark are made by Woodall and there is nothing wrong with them...no matter who's name gets put on them
