Old 12-14-2017, 09:10 AM   #1
PGG
Acid dipping a whole truck body before paint
Is there anyone still doing this anywhere especially in Texas or near North Texas?
Seems like the best way if you are going to go all the way with a restoration.
Thanks PG
PGG is offline   Reply With Quote
Old 12-14-2017, 10:13 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Acid dipping a whole truck body before paint
There used to be a company that did that for automotive application....can't remember the name but there was a place here local....I had a hood done once...it turned out great...but they are long gone...I suppose the EPA regulations had a lot to do with it....?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-14-2017, 11:34 AM   #3
hemi43
hemi43's Avatar
Be careful acid dipping. The acid will remove rust as well as everything else which is great, the problem is that it will be impossible to access those areas afterwards to apply primer. And yes, I've done this in the past.
hemi43 is offline   Reply With Quote
Old 12-14-2017, 11:49 AM   #4
PGG
Thanks for the heads up but I was thinking if it was all totally dissembled first so you could get behind the body panels etc.
Old 12-14-2017, 12:07 PM   #5
hemi43
hemi43's Avatar
How do you get primer into places like the vent boxes in the cowl area, inside the windshield header and in between pinch seams etc ?
It would be great if there was a way to get the whole body dipped in some sort of primer afterwards, but never heard of that being done aftermarket.
Old 12-14-2017, 12:43 PM   #6
GM man
GM man's Avatar
I've always liked the acid dipping. Seems like the best way to start with a clean sheet, but like others have said, it does create some issues and isn't perfect. I like the Eastwood heavy duty anti rust product for the places that hemi43 was talking about. They have a 2' hose that you can run up into tiny places to spray. I'm sure it's hard to completely cover all those places, but that product is really good. There were a couple of places around Lewisville that did the dipping, but don't know if they're still in business. I'll see what I can find out.
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 12-14-2017, 01:28 PM   #7
stangtjk
It true you probably won't access these areas to prime however in my experience the thin factory coating in these hidden areas no longer exists and it's all covered in surface rust anyway.. I'm from the salt belt though so maybe vehicles from dryer areas don't have that problem.
I recently cut the inner bedsides out of my blazer just so I could prime and coat between the quarter panel and bed. There was very little factory primer left in that area, probably 95% surface rust.
stangtjk is offline   Reply With Quote
Old 12-14-2017, 01:59 PM   #8
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
At one point there was a guy on here that was acid dipping and then dipping in an epoxy primer sealant... Cant really remember much about it but it had to have been 10 years ago... Always thought it would be the way to go but never had the money to do it...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 12-15-2017, 07:47 PM   #9
Blazer690
Blazer690's Avatar
Try the name Redi Strip it was in So Cal and moved east
Blazer690 is offline   Reply With Quote
Old 12-15-2017, 09:07 PM   #10
hemi43
hemi43's Avatar
FWIW, here's a 1928 body I had done a few years ago. Amazing results. I used a syringe to inject activated epoxy into the pinch welds.
Old 12-16-2017, 12:09 AM   #11
Rods
Rods's Avatar
I have acid dipped all trucks I have restored and love the way it turns out. I also have a rust protection done after dipping. Check with who ever you decide to do your dipping and see if they offer the rust treatment. It has worked out great for me.
Rods is offline   Reply With Quote
Old 12-16-2017, 06:56 AM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Its good for certain parts but, to get a primer into some areas after dipping is impossible. Even with creative methods. Maybe in dryer climates it would survive, but down here it is a death sentence to these old steel vehicles.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 12-16-2017, 03:38 PM   #13
Bigdav160
Bigdav160's Avatar
Those areas were not treated from the factory, were they?
I think it would be good as long as the acid can be properly neutralized.
BTW, my Z28 was primer dipped from the factory. It still rusted.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-17-2017, 01:52 AM   #14
GM man
GM man's Avatar
This is why I like Eastwood anti rust. It's waxy and self heals if it gets scratched. The 2 foot extension wand is good for getting it into hard to reach areas. For sure, the metal that gets a coating won't rust.
