Old 12-21-2017, 07:33 PM   #1
x's1969
Truck Wont Start
I have a 1969 Chevy c10 that I just purchased about 2 months ago. I drove it on a Friday and drove well no problems, I go to drive it on Saturday and the truck doesn't start. There was one click when I went to start it and nothing after that. No humming no clicking,nothing. I tried turn my lights on and didn't have any power. Head lights, Tail lights, Turn Signals, dash lights don't work. The starter has 14 volts I go to turn it on and it goes to zero. All the fuses in the fuse box are at 0. The battery, alternator, headlights/headlight wiring harness are new. Just currently lost and have no clue, any help would be greatly appreciated.
x's1969 is offline   Reply With Quote
Old 12-21-2017, 07:36 PM   #2
Perpendicular
Re: Truck Wont Start
Check your battery connections including the ones at the starter and the engine. Sounds to me like there is a corroded connection.
-Paul
Perpendicular is offline   Reply With Quote
Old 12-21-2017, 08:12 PM   #3
Aberdare
Aberdare's Avatar
-Paul
Basics here... Yes! Check Cables, but a battery load test will tell you if you have enough electrons lined up to do the job and turn the starter. Next up is Positive and ground (Negative) connections... If all is good, Bad starter. While a Volt Meter can be useful, an AVR (Amps-Volts-Resistance) meter will be more useful.
Abe
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 12-21-2017, 10:42 PM   #4
68c10airstream
68c10airstream's Avatar
Welcome aboard. Look at the battery cable ends at the battery. If they have been cut and a replacement ends put on and you can see the individual wire strands you will fight this for ever because air, battery acid vapors are getting into the cable strands and getting corroded causing voltage drop under load. Those replacement end clamps were considered "emergency clamps".
If you do replace cables watch out for china crap with fewer strands, and rock hard plastic insulation. American made standard plus brand has been very good if they are still usa sourced.
Being that you have a volt meter, your answers are a test away. Scrape the top of the posts shiny, stick one lead on say the positive post, and pierce the positive cable with the other lead just downstream from the clamp. Have somebody crank it over and read the meter. .3 volts or more equals repair. Ignore if the meter shows a - symbol next to the reading. I just means your leads are reversed from the electrical flow. Do the same at the negative post. Another test is to feel the clamps, etc, while somebody holds the key in the crank position. You may get burned, but the resistance is very warm/hot. Good luck.
To keep it easy, the test stated above makes the meter into a jumper cable because you are parallel to the cable being tested. With resistance present, it's easier for the voltage to go through the meter than through the resistance, so the reading is telling you how much is needed to boost it up to what is needed. It's called a "voltage drop test". Probably the best test i learned for electrical repairs.
68c10airstream is offline   Reply With Quote
Old 12-21-2017, 10:45 PM   #5
70 C/K 20
Check all the ground connections.
70 C/K 20 is offline   Reply With Quote
Old 12-21-2017, 11:05 PM   #6
57larry
grounds, then it's fire or fuel
57larry is offline   Reply With Quote
Old 12-22-2017, 01:02 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
This is the failure mode for modern batteries. Batteries used to fail more gracefully and you had some warning. Now, they just drop dead. Make the checks suggested, and take the battery to a parts store or someone with a tester.
~Steven
Simi Valley, CA
Old 12-22-2017, 02:24 PM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I had an intermittent starting problem with my driver somewhat recently. Can't say I know how to use volt meters and that yet, but odds are great if your cables are good then your battery is bad. I had a spare battery, starter and ground cable and installed them. The ground cable was definitely bad and in the wrong spot anyhow. At any rate, it starts.
You might check your alternator too.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-22-2017, 02:38 PM   #9
demian5
demian5's Avatar
Check that the connection at the plastic junction at the fender is clean. I had one that wouldn't start after running, it was filthy and had been painted over as well.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
