Old 12-16-2017, 09:26 AM   #1
Faastone27
Faastone27's Avatar
need advice on window regulator adjustment
Hey guys , so I read ALL of the threads and watched ALL of the videos on replacing window regulators. I successfully tackled it but when the window is all the way up it is pretty hard for the first few inches when rolling down the drivers side. What, if any adjustments can be made to "loosen" it up? Everything is well greased, I am sure the same thing was happening with the regulator i took out and that is why it ended up stripping the gears in that area. I think i will loosen up the rear guide and see if that does the trick and if so simply enlarge the holes to adjust.
Faastone27 is offline   Reply With Quote
Old 12-16-2017, 07:18 PM   #2
jessemthompson
Re: need advice on window regulator adjustment
Is all of your weatherstrip in the track properly? There isn’t an adjustment for the regulator. It sounds like something isn’t lined up properly.
jessemthompson is offline   Reply With Quote
Old 12-16-2017, 08:48 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
What Jesse said. If everything else is right, then seems to me the regulator is bad.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-17-2017, 10:41 AM   #4
Faastone27
Faastone27's Avatar
Thanks for the responses. Looks like everything is in place but i will take a look at it a little closer today and see if I can see anything that doesn't look right.
