Old 01-10-2018, 09:42 PM   #1
69ls4.8swap
air conditioning and fuel tanks
I have read thru some great threads and have gained a ton of knowledge, sometimes too much, on swapping to a 4.8 lq4 engine. I'm sorry if i have overlooked a thread on this. My 69 c10 is an ac cab truck and the 4.8 i am installing has a brand new ac compressor that i would like to reuse. I'm not in a position to put a retro system in and am wondering if anybody has used the ac pump from a ls to work with the 69 ac box. The ac worked great before i removed the 350 and i have capped all the lines and fittings so no moisture would enter.
Also I want to move the gas tank under the bed between frame but have the fuel fill come out behind license plate like on my 70 chevelle, and install a flip down plate. Any body make some suggestions with sender and intake fuel pump?
Thank you in advance.
69ls4.8swap is offline   Reply With Quote
Old 01-11-2018, 10:44 PM   #2
jessemthompson
Re: air conditioning and fuel tanks
There are a few companies who make the 69 Camaro fuel tank with an in-tank pump for fuel injection. There are some forum members who have used them and the inlet would be behind the license plate.
jessemthompson is offline   Reply With Quote
Old 01-11-2018, 11:38 PM   #3
thehata1
As for the A/C, I have read too many threads to recall which one was best. There are a lot of people who try to use a new compressor with an old system. But, the best that I have seen was a build that used all of the newer parts on the old truck. You will have to rebuild the evaporator core box to make it bigger. But, it should be worth it. Sorry I can't be of more help. I believe it in the LS build threads.
Good luck.
thehata1 is offline   Reply With Quote
Old 01-12-2018, 10:00 AM   #4
Clyde65
Clyde65's Avatar
Boyd’s Welding for the tank!
Also, Vintage Air if your replacing your AC. But if your keeping what you have, why not just use the existing and upgrade the Freon?!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-16-2018, 09:20 PM   #5
69ls4.8swap
Lightbulb Re: air conditioning and fuel tanks
Trying to keep on a budget. There was a guy who messaged me and said he used a 87 blazer tank, gm15c, with a 87 blazer sending unit that looks like it has correct ohms,0 to 90, but had a aero pump that was crazy expensive. Does anybody know of this ep381 a.c. fuel pump will fit in said sending unit? Any mods? Thanks
Old 01-16-2018, 09:28 PM   #6
jessemthompson
Prior to my Boyd tank I ran the 87 blazer tank. The EP381 will work with it, but the filler won’t go through the license plate.
Old 01-16-2018, 10:10 PM   #7
69ls4.8swap
Where did you end up putting your fill jesse?
Old 01-16-2018, 10:46 PM   #8
jessemthompson
I had a bed floor fill. I cut the curved neck off and welded on a straight neck with a fill cap.
Old 01-17-2018, 09:03 AM   #9
nsb29
nsb29's Avatar
I remember years ago when cars had the Flip down license plate to put gas in your car especially the ones taking off from the light and spewing gas all the way across the intersection but of course gas was only about $.35 a gallon
nsb29 is offline   Reply With Quote
Old 01-17-2018, 07:51 PM   #10
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I use the stock 5.3 compressor on my 87. The evaporators are similar size, also am using the stock condensor.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-17-2018, 09:00 PM   #11
weq92f
weq92f's Avatar
The ls pump is going to be 134a so you'll have to convert the guts of your system to that. Many report the results are not that great so depending on your A/C performance expectations, you may want to do some research before taking the plunge. Check the cost of just the VA under-dash unit and controls since you have everything else. Might not be too bad compared to what it would cost to convert what you have now.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
