Old 02-07-2018, 09:13 PM   #1
statenine
statenine's Avatar
CPP engine mount perches question
I went to install my CPP 6372MP-SM perches today, but I am not sure where to mount them and the directions that came with them are useless.
On the passenger side, there are 3 holes in the frame (stock perch was bolted to the rear two holes). But on the driver side, there are only the 2 rear holes.
So my question is, do they mount in the rear holes and then I have to drill the lower holes in the crossmember? Or do they mount in the forward holes and then I have to drill a 3rd hole in the frame on the drivers side?
statenine is offline   Reply With Quote
Old 02-07-2018, 10:08 PM   #2
rmvlt1100
rmvlt1100's Avatar
Re: CPP engine mount perches question
Im not sure if they bolt up the same way, but, here is a couple of pictures of my mounts.
Drivers Side:
[IMG][/IMG]
Passenger Side:
[IMG][/IMG]
Hope this helps.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 02-07-2018, 10:21 PM   #3
statenine
statenine's Avatar
Hope this helps.
Thanks! So you used the forward holes. Did you have to drill a hole in your frame on the driver side?
Old 02-07-2018, 10:25 PM   #4
Clyde65
Clyde65's Avatar
Should be 3 holes on each side on top rail.
Hole on crossmember is to the rear only. If your putting in front two holes of frame rail, you will need to drill.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-07-2018, 10:49 PM   #5
statenine
statenine's Avatar
Thanks Clyde, however mine only has 2 holes on the drivers side. Also, when I put the perch in the front 2 holes of the frame rail, the bottom mount aligns perfectly with this hole:
Old 02-07-2018, 11:33 PM   #6
rmvlt1100
rmvlt1100's Avatar
I can not remember if I drilled any holes. Its been a few years. Enjoy your build.
Old 02-08-2018, 07:08 AM   #7
NC_John
NC_John's Avatar
If you have any plans (or the possibility) that you might later install the no limit rack and pinion steering kit, use the rear holes. I had to drill a couple holes to do so on my 70 but can't remember if they were on the frame rail or crossmember.
They say the handling is improved by moving the weight of the drivetrain back, even just an inch, but I am doubtful you could notice it on one of these old trucks.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 02-08-2018, 01:56 PM   #8
statenine
statenine's Avatar
Thanks all. Yeah, so if I use the front 2 holes, I will only need to drill one hole on the driver side frame rail and would then be done.
If I use the rear 2 holes, I will need to drill 2 new holes in the crossmember.
I am fine going either way, just don't know if there is a "correct" way...
