Old 02-27-2018, 09:27 AM   #1
brown7373
brown7373's Avatar
Crate 350 - no holes to mount plug shields
My 350 crate engine does not have holes on one side of the block to mount the spark plug shields. I assume that drilling and taping an engine on a stand is nearly impossible. Anyone solve this?
brown7373 is offline   Reply With Quote
Old 02-27-2018, 09:36 AM   #2
Mike C
Mike C's Avatar
Re: Crate 350 - no holes to mount plug shields
Cast iron drills and taps easy. Are the bosses present in the casting? My concern would be drilling into water jacket. But if bosses present and use a drill stop and bottoming tap should be straightforward.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-27-2018, 10:35 AM   #3
Keystone_Hate
Don't run the heat shields. Why would you spend the time and money, possibly risking completely screwing your block, to run a $20 part that really doesn't do anything?
Keystone_Hate is offline   Reply With Quote
Old 02-27-2018, 11:12 AM   #4
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
You are likely missing the hole at the rear of the passenger side. Julio thinks the starter brace hole is it and thinks it is done. I just drilled and tapped the second one in a year last week and it is not that much of a job. They have no doubt built thousands without this hole. Measure the depth of one of the holes and measure the location precisely. Check the drill size by fitting a drill bit into one of the holes. You will need a bottom tap. Good luck. Roger
P.S. If you are missing more than one hole I would call the engine supplier and invite him to send someone over to do the job.
CaptRMW is offline   Reply With Quote
Old 02-27-2018, 11:56 AM   #5
B. W.
B. W.'s Avatar
Mine doesn't have holes either. I didn't run heat shields.
B. W. is offline   Reply With Quote
Old 02-27-2018, 12:41 PM   #6
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
If you are running headers the heat shields will not do anything but if you are running rams horn manifolds your spark plug boots will be fried by the heat, or you can get insulating boots to protect them. GM was not known for putting things on these trucks that didn't serve a purpose.
Old 02-27-2018, 07:30 PM   #7
Mike C
Mike C's Avatar
I totally agree with GM not putting things on for no reason. But I have run 2 1/2" 'vette manifolds on my Jimmy for nearly 20 years and the wires have been fine. I routed them down and along the oil pan then back up the back of the block to the distributor. (Buy some 75 Corvette wires if you are running HEI).
I would guess my spiral wrapped Taylor wires and boots are significantly more heat resistant than the vintage GM wires however.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-03-2018, 07:05 PM   #8
brown7373
brown7373's Avatar
I bought a 3 piece tap set on Amazon and a #7 drill bit, used a center punch to mark the spot and drilled and tapped the hole. It was easy to do and took only a few minutes.
