Old 03-07-2018, 02:27 PM   #1
berghandler
How to identify auto tranny type?
I'm trying to make sure what type of automatic transmission that's on my grandsons 1972
C/20 Delux. It has a 350 engine but not sure if it's a t350 or t400. It needs to be replaced and I want to make sure we get it right when looking for another. Can any one out there give me some sure indicators on what to look for to tell if it's a t350 or t400 on the truck now. It is the original tranny.
berghandler is offline   Reply With Quote
Old 03-07-2018, 02:34 PM   #2
demian5
demian5's Avatar
Re: How to identify auto tranny type?
Here you go.
700r-4 also applies to the 4L60 and 4L60-E
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-07-2018, 02:37 PM   #3
HO455
HO455's Avatar
Those are transmission oil pan shapes. Compare them to yours to decide which one you have.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 03-07-2018, 02:37 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here is another one.
LockDoc
Leon
Old 03-07-2018, 02:38 PM   #5
harpo231
harpo231's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1520447840
Hope this helps ...
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-07-2018, 03:19 PM   #6
geezer#99
geezer#99's Avatar
When you look for a replacement, make sure you get one with the correct tail shaft housing length.
Old 03-07-2018, 04:05 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup. It'd be a bummer to get one with the wrong length tail shaft.
OP- see if you can post a picture. It can save a lot of pain. What are the symptoms that you deem make replacement necessary?
~Steven
Simi Valley, CA
Old 03-08-2018, 11:53 AM   #8
berghandler
It slips bad in first gear when starting out, unless you baby it when you take off.
Old 03-08-2018, 01:13 PM   #9
MARKDTN
I would have yours built instead of getting another. You know it fits, you know a little about it. It has to come out anyway, just build it. But you might service it and it may go a bit longer. Could be the filter is clogged. I would at least pull the pan and take a look.
Another tell-apart is a TH350 has the vacuum modulator at the rear of the trans while a TH400 has the modulator on the right side towards the front.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-08-2018, 02:31 PM   #10
cleszkie
cleszkie's Avatar
Originally Posted by berghandler View Post
it is the original tranny.
Check the SPID.
cleszkie is offline   Reply With Quote
Old 03-08-2018, 02:36 PM   #11
68Gold/white
Another...late transmissions do not have vacuum modulators, oldies do...
Powerglide, modulator is behind pan on drivers side
TH350, modulator is behind pan on pass side.
TH400 modulator is forward of pan on pass aide, usually visible from under hood...
68Gold/white is offline   Reply With Quote
Old 03-09-2018, 01:51 AM   #12
3757chevy
3757chevy's Avatar
th350 has detent cable on drivers side of carb. th400 has electric kickdown switch on throttle pedal inside cab
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
