Old 03-24-2018, 05:25 PM   #1
54blackhornet
54blackhornet's Avatar
After Winter Storage No Start ?
I went to retrieve my GMC from storage today and just get a click when I turn the key ? Pulled the Delco battery and took it to NAPA. It checked out fine so now what ? Hate to have to crawl under it right now because I hurt my knee and hobbling around under a truck will be painful, any suggestions would be great, thanks guy’s....
71 C-20
07 Magnum RT AWD
54blackhornet is online now   Reply With Quote
Old 03-24-2018, 05:35 PM   #2
harpo231
harpo231's Avatar
Re: After Winter Storage No Start ?
Clean connections
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-24-2018, 07:08 PM   #3
truckster
truckster's Avatar
If you have clean terminals and a good battery, there's a possibility that the starter solenoid is arcing. When that happens, carbon buildup can keep the starter from turning.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 03-24-2018, 07:23 PM   #4
briank
Push trans selector into park...may not be fully in park and then you will get a no start. My 68 gmc burb use to be like that.
briank is offline   Reply With Quote
Old 03-24-2018, 11:19 PM   #5
franken
Get a voltmeter. I had a parts store tell me my battery needed a charge--it was old and read 9V w/ no load. They have no idea what they're talking about.
Charge the battery slowly for a few days.
Old 03-25-2018, 01:21 PM   #6
54blackhornet
It’s not the battery, NAPA put a big load on it while testing it. I only use side screw in terminal Delo battery’s, can’t depend on post type connections and hate the corrosion they produce. Guess I’ll have to go down below and pull that heavy sob. Maybe time to consider one of those lightweight fellas ?
71 C-20
07 Magnum RT AWD
