![]() Join Date: May 2011
Tilt Steering column
Who's got a source for switch cover puller j 22708?
![]() Join Date: Jul 2016
Re: Tilt Steering column
You can remove the cover with a screwdriver and a hammer, ive done it dozens of times, use your best newest screwdriver with a sharp edge, there is a groove on the bottom I think, cant remember the exact location. Start there then move around. Helps to secure the column is a holding fixture nice and tight. Also use the tilt mechanism to get best access.
You can borrow my puller with a deposit and pay shipping both ways....I would need a $150 deposit.... |
Here is one on ebay, I think the only difference is the pressure bolt is shorter, different part number but It might be the same tool.
https://www.ebay.com/itm/N16B-Kent-M...4383.l4275.c10 |
Thanks for the offer on borrow. Saw the ebay deal,may go for it.Switch is bad gotta get it out.Paul.
Old member
I took mine off without any effort. I twisted and pulled up it came right off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Be nice to get lucky like that,this ones been rebuilt and is tight.
#7 | |
Old member
![]() Quote:
