Old 03-09-2024, 02:27 AM   #1
Luke87gt
1967-1970 c10 with 15x10 rears - what offset?
Hi guys, I have a ‘69 which I understand has a rear that is 0.75” narrower per side than ‘71-72.
I’d like to run a 15x10 rear rally but I’m not sure on the backspacing. I see that 4.0”, 4.25”, 4.5”, and 5.0” are widely available.
I don’t like a look that’s too pushed out or too sucked in. What do you recommend? Any pics would be helpful. Thank you.
Luke87gt is offline   Reply With Quote
Old 03-09-2024, 11:07 AM   #2
geezer#99
geezer#99's Avatar
Re: 1967-1970 c10 with 15x10 rears - what offset?
Here’s a link to one of many fitment guides.
You can use simple tools or buy a wheel rite like in the link.
https://www.chevyhardcore.com/tech-s...els-and-tires/
Old 03-09-2024, 11:32 AM   #3
68bowtie
68bowtie's Avatar
Double check your rear width, you never know if it’s been replaced with the other size.
I don’t recall what rear I have in my 68 (converted to 5-lug at some point by the PO), but I measured carefully and went with a custom backspace through Wheel Vintiques. It’s snug as a bug with 5/8” clear to the wheel wells on the insides.
Old 03-09-2024, 09:47 PM   #4
Luke87gt
Thank you!
If anyone has any other pictures of 15x10 with 4.0 - 5.0inches of backspacing, that would be helpful
Old 03-09-2024, 10:34 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
How much power do you plan on putting to the ground, or is this just for looks? I responded to your fuel line thread; I think you should take a look at your ultimate goal before buying too many parts. If you want to go full gonzo, it would be nice to know that up front. We can help you with that, in many ways.
~Steven
Simi Valley, CA
Old 03-09-2024, 10:44 PM   #6
hewittca
hewittca's Avatar
I just put some 15x10 with 5.25" BS on my '72 with the wider rear end. I have also removed the inner fender which let me run so low with only 1/2" between tire and fender. Your backspace will be more critical the lower you go. If you're tucking tire then you have to pretty much nail the BS because squeezing a tire that wide between the inner and outer fender doesn't leave you much clearance.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 03-10-2024, 02:33 AM   #7
Luke87gt
For the foreseeable future, this is just for looks. All my projects have had aggressive wheel/tire fitment
Long term (5yr) plans will include power however - I’m guessing somewhere in the neighborhood of 500rwhp
For the coming years, I hope to get very familiar with the 250 that’s in there now (assuming I can get it running)
Old 03-10-2024, 08:55 AM   #8
PowerdbyChevy79
PowerdbyChevy79's Avatar
Man that Stance is *****in..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
